View Poll Results: Which is the BEST kit
Huron V1 truck manifold turbo kit
51
66.23%
On 3 Performance No AC turbo kit
20
25.97%
CXRacing turbo
6
7.79%
Voters: 77. You may not vote on this poll
Huron V1 VS. CXRacing VS. ON 3 Performance
Old Jun 24, 2014 | 09:31 PM
Dzel's Avatar
Default Huron V1 VS. CXRacing VS. ON 3 Performance
So it's time for me to pick one of these turbo kits for my 2002 WS6. The car was once Procharged but now it's waiting for some boost. I've been looking into all three of these kits for the last two weeks. I still have the stock K-member and sway bar. I'll be adding a Boost Leash Progressive boost controller. AC has already been removed. All kits have been priced with a 76 mm T4 with a 1.15 housing. They are just a few hundred bucks from each other. So I really would like the communities input on what you all believe is the best kit. I'll notate my pros and cons under each link.
http://on3performance.com/LS1NoAC.aspx
I've heard a couple of horror stories.
http://shop.huronspeedproducts.com/F...s1turbokit.htm
This kit is actually here in town for a great price. But I will need to find some truck manifolds, oil line kit, and I'll need to drop my sway bar.
http://www.cxracing.com/mm5/merchant...NG-AM-CRUZ-14T
This kit is the cheapest one out of all, but it retains the stock MAF sensor and actually uses it after the 90 coming off of the Throttle Body. I have a deleted MAF sensor. So I'll need to track one down.
Your help is greatly appreciated.
Old Jun 24, 2014 | 09:44 PM
sbcgenII's Avatar
Buy a welder.
Old Jun 24, 2014 | 10:14 PM
1bdbrd's Avatar
I looked at all 3 of these kits before I bought mine. I went Huron because I found a great deal on mine but also because of a few other reasons.
On3:
1. Thinner walled stainless (I didn't want to worry about potential cracking issues)
2. Needs a scavenge pump (some don't use them but I wouldn't take the chance)
3. By the time you add in a better turbo (their 76 at the time wasn't going to cut it for my goals), better wastegate and bov you were approaching the Huron kit price.
CX Racing:
I asked them a few questions and didn't really seem to get much back in return. Just horribly written English with no real answers in them.
Old Jun 24, 2014 | 11:42 PM
sweet99ss's Avatar
Huron speed.
1. Better kit
2. Customer service
3. CUSTOMER SERVICE!
Old Jun 25, 2014 | 07:24 AM
munn79ta's Avatar
i went with on3 kit. customer service has been just fine. you don't need a scavenge pump you can gravity feed the drain, just make sure you get a good pcv system but thats with any turbo setup....i couldn't justify paying so much money at the time for just piping with other kits available. i think all the kits have their own little quirks its just up to you on what you decide and fits your budget the best.
Old Jun 25, 2014 | 07:42 AM
Blackpanther99's Avatar
Huron Speed.
Old Jun 25, 2014 | 08:01 AM
Rise of the Phoenix's Avatar
I'm interested in what others have to say as well.
Old Jun 25, 2014 | 08:51 AM
big reg's Avatar
Huron Speed with the new ON3 78/75 Turbo. Over 1k cheaper than the Turbonetics units and built with the same parts from the same supplier.
Old Jun 25, 2014 | 09:50 AM
Sales1@Texas-speed's Avatar
Huron Speed because the quality and customer service you get from them is excellent!
Aaron@Texas-Speed
Old Jun 25, 2014 | 09:55 AM
c0ncEpT's Avatar
Aaron@Texas-Speed
Agreed. I'm on my 2nd Huron Speed turbo kit. The quality and customer service are 2nd to non. Jon prides himself with bringing you the best product at the best price with lights out customer service.
Old Jun 25, 2014 | 11:45 AM
02LS1ram's Avatar
Huron speed without a doubt.
There customer service is of the best out there.
If you have a problem there right on top of it.
Don't even think about order there kit and don't look back
Old Jun 25, 2014 | 11:56 AM
steveo_f8's Avatar
Huron Speed. For all the reasons mentioned above
Old Jun 25, 2014 | 01:04 PM
OP, you reference that the three kits are within a few hundred bucks from each other, but the Huron Speed kit is quite a bit more expensive once you add in the turbo, BOV, waste gate, etc. The other two kits already come with the turbo, BOV, and waste gate, so they are significantly less expensive.
Old Jun 25, 2014 | 01:52 PM
Dzel's Avatar
The Huron is actually being sold here locally to me for 2200 with all the above mentioned.
Old Jun 25, 2014 | 02:16 PM
I see. Sounds like a good deal.
Old Jun 25, 2014 | 02:38 PM
caMnaro's Avatar
I dont have any first hand with either kit, but since no one mentioned this article. Seems they liked the cx racing kit, it made good power and they thought it was built well.
http://www.superchevy.com/how-to/eng...urbo-kit-test/
Old Jun 25, 2014 | 02:55 PM
Is the new On3 turbo a direct fit onto the CX Racing kit?
Old Jun 25, 2014 | 04:48 PM
Dzel's Avatar
It's all T4 right?
Old Jun 25, 2014 | 04:54 PM
big reg's Avatar
Any T4 turbo will work. The on3 turbo will bolt up to any T4 based kit. If you placed it side by side with a Turbonetics unit, other than brand names on compressor housings they are identical.
Old Jun 25, 2014 | 05:02 PM
Hi-Po's Avatar
Huron Speed.
