Huron Speed guys???
Old Jul 15, 2014 | 02:12 AM
SPRAYED Z's Avatar
Default Huron Speed guys???
Anybody using a pt88 turbo or comparable with a 4" down pipe?
Does it work with one and if so what does yours look like?
Its a V1 kit and im told they do differ in design from the V2. So I know the wastegate placement is diiferent. But stading up the radiator and having push fans should equate to a V2 setup
Any pix or ideas lmk
that would be great.
Old Jul 15, 2014 | 11:42 AM
jrpimp00's Avatar
Probably wont help but i have a v1 kit and added a t4 to t6 transition flange on it and running a s480. It sat just a lil over 1/4" from the radiator and my blanket is touching it. im running a 4" dp but its going to be dumped out the front fender
I dont think a 4 inch dp will fit unless youre running a turbo k member, thats if youre trying to run it out back
Old Jul 15, 2014 | 12:01 PM
a-low's Avatar
Got any pics?
Old Jul 15, 2014 | 03:54 PM
SPRAYED Z's Avatar
U mean a bumper exit right?? NOT a fender exit?
If it worked with a t6 then it will work on a t4. The turbos are virtually identical as for placement. Yes I see you being closer to the radiator but bends will make it stray away from the WG and radiator/core support
Old Jul 15, 2014 | 05:54 PM
jrpimp00's Avatar
LOL, yeah i meant bumper. Will get some pics tomorrow
Old Jul 15, 2014 | 08:58 PM
blackbird0230's Avatar
a friend is running this hsp v1 kit with a pt88. needed a turbo k member and will add supoort to help hold turbo. He also made the radiator stand vertical to get more room
Old Jul 15, 2014 | 09:07 PM
HolyShiznit's Avatar
Jon @ Huron Speed told me that a PT88 (T4) will fit on the V1 kit, however the bottom part of the radiator might need to slide slightly forward (where the ac condenser would have been).
I will know in a few days as I am replacing the 7475 on my V1 kit with a PT88.
Old Jul 15, 2014 | 09:39 PM
c0ncEpT's Avatar
A PT88 will fit Jon's V1 kit. Local guy had one with a bumper exit exhaust. He didn't stand the radiator up either and it still cleared.
He did have to add a 2nd wastegate to really control the boost tho.
Old Jul 16, 2014 | 07:59 AM
Superman09's Avatar
LS1Tech Sponsor
Yep, PT88 will fit the V1 kit. We installed one and pushed bottom of the radiator forward a little for more clearance but left the top in same location. I cannot comment on =how the V2's 4" down pipe will fit with the V1 kit and a PT88 but I am sure it would be very close as turbo placement is quite similar!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Jul 16, 2014 | 03:50 PM
transamfreak01's Avatar
I'm glad I saw this post bc I was wondering this too. They told me with my 408 to not go with v1 t4. Now I'm interested. More info on this please
Old Jul 16, 2014 | 03:52 PM
Superman09's Avatar
LS1Tech Sponsor
Our new T4 V2 kit can fit mid frame T4s without having to route the factory radiator or position and includes a 4' bumper exit down pipe as an option for them as well!
__________________
