New lsx build! Need opinions
Old Jul 16, 2014 | 10:43 AM
Lsxs197's Avatar
Default New lsx build! Need opinions
Hey guys new to this forum. Pretty excited, I hear there are a lot of helpful people on here!
Here's my questions. I'm building an lm7 for boost. Not trying to kill the motor but I am using stock crank, rods, and pistons. I plan on changing the cam, lifters, pushrods, rocker arms, and valve springs. I'm hearing ls6 is the best cam for these engines when going turbo. But I still want that lopey sound at idle. One more question is I found a great deal on 241 heads, will they work on my lm7?
Old Jul 16, 2014 | 11:59 AM
Brian Tooley Racing's Avatar
What size turbo do you have? The LS6 cam seems to work well with smaller turbos. Larger turbos seem to perform best with cams designed around them.
Here are some results of a SBE 5.3 with a cam kit that we keep in stock.
http://www.yellowbullet.com/forum/sh...d.php?t=948818
Old Jul 16, 2014 | 04:32 PM
Lsxs197's Avatar
Default What size turbo do you have? The LS6 cam seems to work well with smaller turbos. Larg
I think I'm going to go somewhere around a 76mm turbo
Old Jul 18, 2014 | 07:31 AM
Blackpanther99's Avatar
LS6 cam will work great with that 76mm
Old Jul 18, 2014 | 11:36 AM
Lsxs197's Avatar
Will ls1 heads work on the lm7? Without doing any machining to the heads? What head gaskets should I use?
