Help with a diy t6 hotside
Old Jul 16, 2014 | 11:27 PM
transamfreak01's Avatar
Default Help with a diy t6 hotside
So I've been playing with the idea of building my own hotside. I have a months vacation coming up that I have to use so I figure I would try this out. This would be my first time "fabbing" up my own turbo kit so I was looking for some guidance.
I was wondering if there are write up out there on a "how to" with something like this. I can weld so I'm not worried about that but I'm a little lost on where to start and exactly how things should be. So if anyone could point me in the right direction I would appreciate it. Basically looking to copy a build that has some type of directions. Thanks guys
Old Jul 17, 2014 | 01:44 AM
D-Man304's Avatar
Just wing it. lol That's what I'm doing. Learn by trail and error. Just look at all the builds on here and get some ideas.
Old Jul 17, 2014 | 01:51 AM
Haha that's what I'm going to have to do if I can't find some type of guide. I figured it was worth a shot and maybe someone had a link to save me some time and material. Hopefully someone can chime in
Old Jul 17, 2014 | 03:07 AM
BlutVonSchwachen's Avatar
Guide other than the sticky labeled "DIY truck manifold build"?
Old Jul 17, 2014 | 12:59 PM
silverbulletman's Avatar
Pretty easy , I was a first timer this year and gotter done
Attached Thumbnails Help with a diy t6 hotside-image-3278786516.jpg   Help with a diy t6 hotside-image-160358074.jpg   Help with a diy t6 hotside-image-3275624191.jpg   Help with a diy t6 hotside-image-1715984741.jpg
Old Jul 17, 2014 | 01:40 PM
krwyellowZ28's Avatar
silverbullet, those modified manifolds look really good. Are they both truck manifolds or is the less-modified one an f-body? What size/thickness tubing did you use on the RH manifold?
Old Jul 17, 2014 | 06:17 PM
Blackpanther99's Avatar
Looks good.
Old Jul 17, 2014 | 07:46 PM
Yeah I saw the sticky but was looking for a few different set ups. Silver bullet it looks good. Care to share any more details on how you went about building it ?
Old Jul 18, 2014 | 12:01 AM
Umm they are the truck manifolds that I basically cut and sectioned. The passenger one is a little tricky when cutting , but as far as diameter of the add on pipe Its 2.125. The drivers side when cut off has a larger diameter so I bought a 2.125 I'd to 2.125 od pipe to transition pipe
