Corvette Build v2.0
Jeff go get the new head unit and get it installed I'm in for some new jam cam numbers with the new blower!
I also grabbed a set of 15" wheels and LG spindles
Picked up some new injectors, 127s were pretty much maxed at 70psi max fuel pressure
I'm going to replace my oem z06 oil cooler with a fog light mounted cooler to make space for the larger intercooler and avoid impacting ac/radiator efficiency
I also got a larger fuel pressure regulator since my small aeromotive was becoming a restriction. I had 4 spare holley -08an o-ring to -06an male fittings from my fuel rails I didn't use since I used -08 stuff on the rails. It'll match my existing lines and I'll see if it flows ok with the -6 & 3/8 combo returning fuel from the driver rail to the tank.
Got boost? Lol
in with the new
Old F-1A
vs
New F-1A-94
Modified the intercooler mount points on the cradle to shift it rearward. I removed my z06 oil cooler and will relocate an aftermarket cooler behind the fog light.
just need to install my spindles and 15s and hit the dyno next weekend
It didn't work due to the wire set up so I sent it back and they assured me it was ok, and they sent back a new cable as well as new instructions. The instructions call out a blue wire. None of the cables they have sent ever had a blue wire.
I swapped the wires around and still doesn't work
