Anyone broken an ARP head stud?
I had a stud break during a rebuild but the rest were fine. Studs were torqued once for the original build in early '13, then once again on this rebuild just a few days ago. Purchased new from Hinson Supercars October 2012.
Attachment 724957
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Broke very similar, just flush with the block at the base of the threads. Have seen it happen with other's before too.
Not overly common, but any is too many
Or just some motor oil etc.
That perma torque stuff they developed is supposed to be good ****. Used it on my china studs to 80lbs no issue haha.
I called ARP and they basically said tough ****, you probably did some thing wrong either on the torque spec or not threading them down till the bottomed out. I know they bottomed out because the block was new and the threads were clean, and I know that the torque spec was set exactly at what they recommend in their latest instructions. The only useful thing he said was to look for hour glassing on the other studs and run a nut up and down the threads to see if it binds anywhere from deformed threads.
Inspect the other studs then order the replacement.
Mine broke in the exact spot. ARP will not assume liability, as they didn't with me either.
