Twin Turbo vette smoking
Hey guys I'm having a bit of trouble, just installed a TTI twin turbo kit on my 01 Z06. We installed a catch can between the valley cover and the intake vacum nipple. The car has a cloud of white smoke when running. If I go back to the stock hose all the smoking goes away...I'm really confused here...
Hmmm....at idle? Or on decel/lift off? No oil in Dp's or compressors? Based on your description probably not...just trying to figure out what up. I think when I ran a stock style breather line(t'd from both valve covers) I think I ended up running a 1 way valve. It's been so long,..lemme look for pics for routing.
Here you can see the stock routing that causes no smoking. We have the valve cover going to the air filters for fresh air. The valley cover and intake are connected by the stock hose. Don't mind the throttle body, we have that temporarily connected to the bov's for testing purposes.
Here is how we have it routed with the catch can. You can see the only thing we change is the hose going from the valley cover to the intake. Don't mind the actual hoses I just threw some on to show you the routing.
Moderator
Pcv valves were setup so valley cover pcv outlet with a PCC valve. Installed so it could only pull vacum
Then vacuum hose was installed to facilitate the vacuum only from the intake manifold..
The fresh air side is hooked up to the air intake piping for the turbos
Maybe check valves have better flow then PCv valves
