Turbo experts please.
Old May 25, 2004 | 06:50 PM
libertine1015's Avatar
My motor was overboosted once.....2 cracked stock pistons.
Alot of people say the deltagate is crappy, when you buy the T76 kit you get an upgraded WG. Maybe its time to upgrade anyways??
Old May 25, 2004 | 07:11 PM
MYTURBOT/A's Avatar
Originally Posted by Whistler
If you block off the wastegate and take it for a drive, youll be able to isolate the problem. If you hit the gas and see the boost gauge pass the 9.5 mark or wherever youre stuck at, then back off because you've identified the wastegate as the problem from opening too much under pressure.
If it doesnt change a bit at WOT then youre out of turbo.
Like I said, just have race gas in the tank is case the boost jumps up faster then you can react to close the throttle.
My boost goes up to what ever I have it set at and stays there until about 4200RPM then it falls off to 9.5psi. i cranked it up again last night trying a few thing to get it to hold boost but no luck I had it all the way up to 16psi but as soon as i hit 4000rpm it started droping off like always ended up with 10psi @ 6200rpm.
So if I blocked off the wastgate I would Totally over boost my motor up untill 4000rpm
Old May 25, 2004 | 07:50 PM
Whistler's Avatar
Sawzall and Welder Mod
With race gas,low compression, and forged pistons you will be able to run at least 20 PSI, but I understand your concern.
Old May 25, 2004 | 08:21 PM
MIGHTYMOUSE's Avatar
this is starting to sound really familiar.. you are going to have to get a bigger a/r exhaust housing or just get a larger turbo completely to fix your problem.
Old May 25, 2004 | 11:13 PM
Whistler's Avatar
Larger on the exhaust side to lower exhaust manifold backpressure MM?
Old May 26, 2004 | 08:16 AM
yes sounds like the turbine is stalling from the excessive pressure.
his built motor is making a lot of exhaust on that bank.. apparently too much for the little 60hifi housing to pass.
Old May 26, 2004 | 08:58 AM
parish8's Avatar
single digit dreamer
whats your maf reading? at 13psi on a mostly stock 6.0 i often max my maf by 5000rpm, i would say i am at 65lb's of air or higher.
the kit i have has a 2.5" cross over, 2.5" log and a 3" down pipe. with a t76 my boost presure holds steady.
i would think with ported heads you are flowing more air than me and just runing out of turbo.
Old May 26, 2004 | 09:10 AM
SUPER DAVES Z's Avatar
I agree with MM, the turbo is just too small. Get that T-76 on there and I think it will hold boost to redline. May spike because of the small wastegate, but it will hold to 6200 rpm.
Later,
Dave
Old May 26, 2004 | 09:26 AM
MYTURBOT/A's Avatar
My MAF is right at 439gms/cyl @ 5800rpm so it`s pretty much maxed. MM does the T76 have a larger exhaust housing or would I need to go with a larger A/R to lower back pressure?
Old May 26, 2004 | 09:54 AM
parish8's Avatar
looking at that compresor map above at 13psi and 60lb's of air you are completley outside of the map. seems like you are out of turbo to me.
t76 is going to kick *** on your car!!, i made 500rwhp at 12psi thru a 4l80e, tcase and 32"tries
Old May 26, 2004 | 01:27 PM
MYTURBOT/A's Avatar
yea, I can't wait to get the new turbo. I'm also working on getting a engine managment system that uses a 3bar map sensor to replace my stock ECU if that all works out i'm shooting for 600rwhp or more.
Old May 27, 2004 | 08:52 PM
  #32
jessicasgyrl's Avatar
Originally Posted by Caveman
It`s nice to be BLOWN!!! I`ll bet your Wing House girl is fat and nasty. I guess i will find out tonight at the Wing House car show. HaHa
Hey guys...I'm new to the area. Do you have any local hang outs in the area?
Old May 27, 2004 | 09:06 PM
  #33
MYTURBOT/A's Avatar
On Sat night there's a local domestic car club that meets at the corner of colonial and orange Ave. Alot of nice cars and people up there. Feel free to stop by and chat.
