Turbo experts please.
Old May 20, 2004 | 09:25 PM
MYTURBOT/A's Avatar
Default Turbo experts please.
I've been racking my brain trying to figure out why my car won't hold boost. I know that the turbo i have now is way to small(thats is getting fixed real soon ). But i'm getting mixed opinions on wether or not to small of a turbo will lose boost on the top end. I,m running 13psi right now and at about 4000rpm my boost starts droping off to 9.5psi and holds that to 6500rpm. What do you think this is caused by? No matter what boost I try to run it always dropes off to 9.5psi. I've checked my wastgate it seems fine. I've checked all the piping no leaks. BOV seems to be functioning properly and the wastgate signal is coming from the intake. any thoughts will be appreciated. Thanks.
Old May 21, 2004 | 06:17 AM
smokinHawk's Avatar
id say your turbo is running out of air if it always goes down to 9.5psi
Old May 21, 2004 | 07:00 AM
MIGHTYMOUSE's Avatar
where is your wastegate located? didnt you try a couple spots a while back or was that somebody else?
Old May 21, 2004 | 08:02 AM
MYTURBOT/A's Avatar
Yea I tryed mounting the gate on the log like QMP, Didn't work, in fact it wouldn't hold more then 8psi like that. So i mounted it kind of in the original location but it's positioned so the exhaust gases can exit easier. George thinks it might be caused by excesive backpressure I have one of the first design TTi logs that used the 2in I.D log and 1.5in primarys. I'm thinking once I get the new turbo if i'm still having this problem maybe i'll try getting the bigger log from George to see if that helps. Thanks guys.
Old May 21, 2004 | 08:47 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
It can only be 1 of two things, either the backpressure is to great and is forcing the wastegate spring open, or the turbo is starving for air. More then likely its the turbo. Trying the larger manifold is not a bad idea though, 346ci's flowing through only 2"'s is not very good flow wise.
Old May 21, 2004 | 10:23 AM
MYTURBOT/A's Avatar
What do you mean by the turbo is starving for air? Are you saying that it's to small or that the air filter/inlet piping are to restrictive?
If the backpressure is forcing the wastgate open would it still reseal at 9.5psi and hold that boost level? Thanks i appreciate all your help guys!
Old May 21, 2004 | 11:53 AM
did we go over what wg spring you had? if its the origninal 5# or whatever spring then thats your problem.. if you're tune is along enough to run 10psi on pump gas then go ahead and invest in a 10# spring.
on the revised set up for the street kit george mounted the wastegate on the passenger side right after the manifold on the crossover.. i imagine he would reccomend you try that or even put a second one there.
Old May 21, 2004 | 12:27 PM
MYTURBOT/A's Avatar
The spring i have in there now is a 7-9psi spring but i have a manual boost controler also. Kinda funny how the boost drops off to the spring rating? Maybe i'll try to find a stiffer spring. Whats the next couple size up springs?
Old May 22, 2004 | 12:43 PM
MYTURBOT/A's Avatar
I removed the MBC last night and cranked the adjuster screw in on my wastegate to see what would happen got it up to 11psi but it still just droped off to 9.5psi. I'm going to try and find a stiffer spring this week see if that helps any.
Old May 22, 2004 | 02:48 PM
Got Me SOM's Avatar
im thinking its wastegate related and your spring is not up to snuff. only one way to find out. change that sucka out
Old May 22, 2004 | 04:03 PM
Caveman's Avatar
10 & 11 Second Club
It`s nice to be BLOWN!!! I`ll bet your Wing House girl is fat and nasty. I guess i will find out tonight at the Wing House car show. HaHa
Old May 23, 2004 | 09:36 AM
69firebird's Avatar
I was wondering, where can you get these springs for the delta gate?
I have looked and everyone that I hve found wants to sell a complete set of springs for like a bill, anyone know where you can buy them indivifually?
thanks
ed
firebird455@onebox.com
Old May 23, 2004 | 11:53 AM
Got Me SOM's Avatar
She's mighty fine caveman, don't hate!
Old May 23, 2004 | 11:59 AM
MYTURBOT/A's Avatar
Any turbonetics dealer should be able to hook you up with a spring i bought an assortment of three spring from a local dealer for $20. I'm going to go back there monday to have them find me a 11-13psi spring.
Old May 24, 2004 | 10:52 PM
Whistler's Avatar
Sawzall and Welder Mod
Pull the wastegate, slide a piece of sheetmetal in between the WG and the flange to block it off,and bolt it back together. Then take it for a spin to eliminate the wastegate from the situation altogether.
Just make sure you've got good gas in the tank in case the boost momentarily goes higher than you anticipate.
Old May 25, 2004 | 08:01 AM
MYTURBOT/A's Avatar
How high do you think the boost will go with the WG blocked off? I don't want to toast my motor from 20psi of boost.LOL
Old May 25, 2004 | 09:48 AM
LS1TECH Sponsor
Becareful with that test. You will see some BIG boost if you block the WG hole.
Jose
Old May 25, 2004 | 09:58 AM
Shinobi'sZ's Avatar
Jose
Have you ever measured the manifold backpressure to see what it is?
Since your Wastegates are external that solves the disruptance that occurs when the wastegate opens...internal wastegates disrupt the flow and cause the turbine to slow down...then boost will dorp.
You should really measure the backpressure...A Turbonetics 60-1 can move enough air to supply 600hp.
http://turboneticsinc.com/compressor.html?comp=60-1
Also the down pipes are only 2"...that is rediculous.
Old May 25, 2004 | 02:16 PM
MYTURBOT/A's Avatar
I did a back pressure test awhile back and back pressure was pretty high. I think it was 28psi @ 10PSI boost so almost a 3-1 ratio. But that was with a 2.5in down pipe. now i'm running a 3in down pipe so that should help some. But my log manifold is still 2in so i think a majority of my back pressure issues are coming from that. When i was running the WG venting to atmosphere I could here the WG when it opened up but when my boost started falling the WG would remain open, shouldn't the WG close to try and hold the set 13psi. Thanks.
Old May 25, 2004 | 05:02 PM
Whistler's Avatar
If you block off the wastegate and take it for a drive, youll be able to isolate the problem. If you hit the gas and see the boost gauge pass the 9.5 mark or wherever youre stuck at, then back off because you've identified the wastegate as the problem from opening too much under pressure.
If it doesnt change a bit at WOT then youre out of turbo.
Like I said, just have race gas in the tank is case the boost jumps up faster then you can react to close the throttle.
