Is the D1SC generally louder than the P1SC ?
Old May 20, 2004 | 11:46 PM
Fierce-LS1's Avatar
Default Is the D1SC generally louder than the P1SC ?
Just like the title says
Old May 20, 2004 | 11:59 PM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
I heard a p1sc on a mustang about 1.5 years ago and it was louder than my d1sc fwiw.
Old May 21, 2004 | 12:05 AM
Fierce-LS1's Avatar
I guess it depends on how much boost it's making
Old May 21, 2004 | 12:42 AM
Ed Blown Vert's Avatar
I think the D sounds louder.
Old May 21, 2004 | 12:46 AM
BIGBOS's Avatar
I've heard both, I think they sound similar, I heard the F1's are loud though
Old May 21, 2004 | 10:59 AM
99blueCamaroSS's Avatar
I just got done putting a D1SC on my 99 Camaro SS and it is very loud at idle. I would have to say it is about twice as loud as the P1SC, but that is my opinion. At 55mph you can't even hear it. I can try to get a sound clip of it. If you want one PM me. Thanks!
Old May 21, 2004 | 11:24 AM
kp's Avatar
kp
They are not always the same, my newer P1SC is way louder then my older P1SC, I have heard quiet D1SCs also. So I guess if you get a quiet D1SC it wil not be as load as a noisy P1SC or the other around
Old May 21, 2004 | 02:26 PM
LS1Bird's Avatar
There does seem to be pretty big variances in the sounds they make - even at the same pulley level. Here's mine >>
http://www.californiamasseys.com/formula.html
http://www.californiamasseys.com/formula_ati_temp.mpg
Mike M
Old May 21, 2004 | 03:33 PM
Fierce-LS1's Avatar
Thanks for the soundclips LS1Bird. Your unit is pretty loud
Whistle ... whistle ... whisle
Old May 21, 2004 | 04:02 PM
BIGBOS's Avatar
His D-1SC is by far the LOUDEST I've ever heard
I remember when I ordered my D-1SC kit, I would listen to that clip over and over again waiting for it to arrive
Old May 21, 2004 | 06:27 PM
My D1SC has like a screeching noise at idle. It sounds like two pieces of metal are rubbing together, but I checked and everything seems to be fine. Is this normal?
Old May 21, 2004 | 08:19 PM
Blown Ta's Avatar
mine does the samething and i was told it was normal
but it did get less noisy when the weather warmed up,or maybe i just got used to it either way i love the way it sounds
Old May 21, 2004 | 10:19 PM
2000Hawk's Avatar
wow i love that sound it would be great to hear that under my hood and scary anyting that trys to pull up next to give it a run. sweet car.
Old May 23, 2004 | 04:35 PM
LS1Bird's Avatar
It is pretty loud, particularly the whistle at idle. That's the ATI-supplied BOV too. I have some gear noise, but nothing that sounds out of the ordinary. Outside of my garage, it isn't quite as loud as it comes across in that clip - but you won't be sneaking in late at night undetected either!
Mike M
Old May 23, 2004 | 05:43 PM
BIGBOS's Avatar
Your right, an aftermarket BOV makes these things sound crazy
Old May 23, 2004 | 08:00 PM
black_knight's Avatar
Not to hijak the thread or anything, but what is it that makes a turbo or a supercharger system loud? Is it the size of the unit? The Wastegate? The Bov? The placement of the unit: i.e. is a front or rear mounted turbo louder? Are twins louder than a big single? Are turbos louder or are s/c's louder? Does the exhaust setup make any given setup make more FI related noise?
What would one do to make their car sound like a 747?
Old May 23, 2004 | 08:53 PM
mdhmi's Avatar
Keep in mind that anything in a garage is going to sound loud. .
Mark
