Stock head gasket and TTY bolt limit
Old Aug 7, 2014 | 07:06 PM
69-chvl's Avatar
Default Stock head gasket and TTY bolt limit
At what point do you throw gaskets and studs/bolts on these engines? How long did your stock head gaskets last and at what hp and/or boost?
Old Aug 7, 2014 | 07:36 PM
asubennett's Avatar
As soon as you start boosting.
Old Aug 7, 2014 | 08:01 PM
denmah's Avatar
Moderator
ive built plenty of 10 second rides with regular gaskets and tty bolts
pumpgas also
hell my one build was a paper headgasketed 99 4.8 with stock tty bolts, pumpgas, 18psi went 10.72@136mph on a measly 1.75 60ft...
Old Aug 7, 2014 | 08:05 PM
asubennett's Avatar
pumpgas also
But why? For something so cheap - Its just a matter of time. Can it be done? Sure - but again, why?
Old Aug 7, 2014 | 08:18 PM
denmah's Avatar
Moderator
just to see if it would work
calling the emperor naked all on my own
Old Aug 7, 2014 | 09:21 PM
cory32690's Avatar
If for any reason ur pulling the heads then go ahead and swap to head studs but if not I would just leave the motor alone and boost it denmah has pushed plenty of motors for us on stock stuff and has lifted a head that I'm aware of
cory32690's Avatar
Hasn't lifted a head sorry
Old Aug 8, 2014 | 06:48 AM
JRENIGAR's Avatar
9lbs on stock 99 longblock that was boosted from 172k to 232k when it was sold still running good.
Old Aug 8, 2014 | 11:23 AM
69-chvl's Avatar
Interesting results...
Only reason I ask is that you have to wonder if taking the heads off causing more problems than just leaving them on and keeping boost low and the tune-up where it needs to be. This LQ9 I'm starring at has the layered gaskets on it already from the factory.
Old Aug 8, 2014 | 11:49 AM
ScreamingL's Avatar
Changing Names
made 816 on a mustang dyno with TTY bolts
Old Aug 8, 2014 | 11:58 AM
denmah's Avatar
Moderator
im a firm believer in if it aint broke dont fix it.
a few years ago people said you HAVE to run rod bolts and you could never run more than 9psi, cerainly never go 8s on stock motors etc etc
Old Aug 8, 2014 | 12:15 PM
Hank Peabody's Avatar
You'll be pushing the limits of the gen1 rods long before stock bolts and gaskets become a factor!
Old Aug 8, 2014 | 12:28 PM
denmah's Avatar
Moderator
absolutely, i always tell people youll bend the rods out of a motor if you are doing it right before anything else breaks
Old Aug 8, 2014 | 12:33 PM
Ryans99ls1's Avatar
Mine lifted at 630hp. Had 19* in it on E85 which isnt much for that fuel but they lifted. Its setup/tune dependent. I question whether or not the guy before had the heads off and reused the bolts though.
CameronVic's Avatar
If you looked at the timing tables of all the people who say stock gaskets and bolts won't work, you'd surely see a pattern above 100kpa
Edit* just read the post above mine. Lol.
Old Aug 8, 2014 | 12:51 PM
69-chvl's Avatar
This lq9 is an '06, appears to have the h-beams (factory ones).
I figure all that crud (scale, coolant etc) is like gasket sealer lol!!!
Old Aug 8, 2014 | 12:57 PM
denmah's Avatar
Moderator
yeah leave all the **** where it is lol
Old Aug 8, 2014 | 01:25 PM
hellbents10's Avatar
LS1Tech Sponsor
I agree, I do not see the point in pulling heads on a JY engine. Just slap a cam/springs/pushrods in that thing and rock and roll.
Old Aug 8, 2014 | 02:34 PM
denmah's Avatar
Moderator
strait from the horses mouth.
no offense obviously!
Old Aug 8, 2014 | 08:01 PM
69-chvl's Avatar
I had no idea folks were pushing stock gaskets this hard - good to know!!!!!!!!!!
