5.3 Turbo build
Old Aug 9, 2014 | 03:40 PM
TLEHN's Avatar
Default 5.3 Turbo build
I'm building a 5.3 turbo want to keep it budget minded for now was curious what cam and where do I get it. Springs also. What turbo do you guys recommend? I'm shooting for 500whp and would like to have drivability as well will be going with a built 4l80 this is going in a 78 c-10 thanks any input is appreciated. Open to tips and ideas as this will be my first build ls
Old Aug 9, 2014 | 04:01 PM
Blackpanther99's Avatar
On3 78 turbo will get it done. You can run a LS6 cam with ls6 springs or just get some Brian Tooley springs.
Old Aug 9, 2014 | 04:44 PM
F110Mech's Avatar
500rwhp? stock cam, ls6 springs, on3 turbo. look at some of Denmah's builds
Old Aug 9, 2014 | 09:47 PM
TLEHN's Avatar
thanks
Old Aug 10, 2014 | 04:34 AM
Mongoose350's Avatar
Rod bolts too. You won't need them at 500whp, but you're gonna turn it up at some point and there not expensive. While you in there go ahead and gap the rings. Just to play it safe.
Old Aug 10, 2014 | 07:53 AM
1969x11's Avatar
You dont need rod bolts or gapped rings. On3 turbo with a homemade flipped manifold hotside and an ebay intercooler kit will get it done on the cheap.
Old Aug 10, 2014 | 08:05 AM
Agreed^
Old Aug 16, 2014 | 09:32 AM
TLEHN's Avatar
ok thanks guys for the info
