How much boost should i be able to make??
Old May 21, 2004 | 04:13 PM
96SCTA's Avatar
Default How much boost should i be able to make??
I have a vortech v2-SQ, With a 2.75 pully and the stock (vortech supplied) crank pully, This is on a heads and cam with full bulltons lt1. Im seeing only 5.6 pounds of boost at 6,000 rpms and thats it. What do you think ??
Old May 21, 2004 | 04:16 PM
MECHAM's Avatar
sounds about what i had..heads/cam/full bolt ons
same pulley...same charger
~5.5 psi
Old May 21, 2004 | 04:17 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
What size crank pulley, the LT1 ones are 7.___ something right?
Old May 21, 2004 | 04:18 PM
MECHAM's Avatar
changed the charger to a T-TRIM same pulley
whenever I hit the peddle..saw instant 5psi!
then at redline ~11psi
no other mods were done
96SCTA's Avatar
im not sure what the size is, Its the one they sent me in the kit. What can i do to get this up to 9psi ??
Old May 21, 2004 | 04:20 PM
MECHAM's Avatar
2.5 pulley or larger sc
Old May 21, 2004 | 04:24 PM
96SCTA's Avatar
Old May 21, 2004 | 04:26 PM
MECHAM's Avatar
[QUOTE=96SCTA]im not sure what the size is, Its the one they sent me in the kit.QUOTE]
normally...the kits are sent with a 3.12 pulley
MECHAM's Avatar
Old May 21, 2004 | 04:28 PM
96SCTA's Avatar
[QUOTE=SC-MECHAM-WS6]
The kit came with a 3.33 inch pully for the blower
The question that psj asked me was how big was the crank pully. Thats what i did not know.
Any ways what can i do to my current set up to get more boost. And where do i get the parts. .. Thanks
MICAH
Old May 21, 2004 | 04:32 PM
LS1Tech Co-Founder
we
need
to
know what size the crank pulley is, maybe go to their website or email jsnee@vortechsuperchargers.com.
LS1 kits come with 8.00 crank pulleys and LT1 kits do not.
Old May 21, 2004 | 04:37 PM
96SCTA's Avatar
So I am assuming that once you find out the size of the crank pully you may recomend getting a larger one. Has anyone done this on an lt1 ??
Old May 21, 2004 | 05:16 PM
LS1Tech Co-Founder
How much boost are you shooting for?
Old May 21, 2004 | 05:37 PM
96SCTA's Avatar
Im Aiming for 8-9 psi. Since its a stock bottom end i know she cant take much more.
I sent an email to vortech and they said they they have 6.66 inch crank pulley that would get me another 2-3 lbs of boost. But they said they do not know what size belt I would need becasue they have never sold this type of combo before.
Any one have any input on belt size.
Thanks PSJ for the email link.
Micah
Old May 21, 2004 | 06:35 PM
LS1Tech Co-Founder
What size crank pulley do you have now?
I have two LT1 buddies who I can check with who have done anywhere from 6 to 15psi.
Old May 22, 2004 | 07:27 AM
2001WS6Vert's Avatar
I've never understood how some guys see 13lbs. with the G. I saw 5lbs. with the 2.75 on a 418 C.I.D.. I saw 6lbs. on the 346 with the 3.15 and just headers. I think the 9lb. claim for the system is misleading. I never knew about the smaller crank pulley, thats interesting.
Old May 22, 2004 | 07:15 PM
96SCTA's Avatar
I still have not figured out what size crank pully i have. All i know for a fact is that it has to be smaller than 6.66 inches. Looks like i will just have to buy this new pulley , hook it up and then find out how short the belt it and order one that is longer. Not the best method but looks like the only way to do this as of now
Old May 23, 2004 | 12:28 PM
LS1Tech Co-Founder
Did you buy the blower new as a full kit? Then get the order # and then we can look it up.
Old May 23, 2004 | 03:33 PM
Inspector12's Avatar
TT-TECH Veteran
Be very carfull with the SQ versions they can't take the abuse that the spur cut gear units are taking. Just a warning. You might look into a larger charger maybe a t-trim like SC-Mecham-ws6 is suggesting. Good luck!
Old May 24, 2004 | 11:39 AM
LS1Tech Co-Founder
Email zbass28@aol.com and he should be able to tell you what crank pulley you have.
He has a 355ci LT1 with heads, cam, 9:1, FAST b/b piggback, M6, and S Trim pulleyed for 10-15 psi.
