TC7875 with 1.1ar
Old Aug 26, 2014 | 09:18 PM
4doortypels's Avatar
Default TC7875 with 1.1ar
On an ls2 402... back pressure issues?
Any 400 plus guys running the this ball bearing unit?
Old Aug 26, 2014 | 09:20 PM
willizm's Avatar
the details... overwhelming
Old Aug 26, 2014 | 10:10 PM
Pretty simple... anyone running a single turbo tc7875 1.15 ar on a ls2 based 402...
I was thinking forged ls2 or 402 front mounted turbo on a cts v1... with the upgraded 75mm exhuast wheel vs the 68mm... anyone running that turbo on a 400plus motor
Old Aug 26, 2014 | 10:36 PM
F110Mech's Avatar
Back pressure issues are going to be dependent on the cam and not just the c.i.
Old Aug 27, 2014 | 09:20 AM
running a 219/230 .605 .604 117LSA in my ls2 (ls3 top)
was thinking maybe 224/236 .620 .620 116LSA on the 6.0L and maybe same specs for a 402... want daily friendly grind. currently 30 mph I get no bucking or surging in 6th. can skip shift if I want to 1-4 at 17-20 mph.
basically wanna do a forged bottom end. if back pressure wont be an issue rather have a few more cubes to move a 4200 lb ctsv
Old Aug 29, 2014 | 10:33 AM
STEEPSS's Avatar
My car doesnt buck in 6th at 60mph. .... .. ....engine speed is not correlated to vehicle speed.
Old Aug 29, 2014 | 11:48 AM
DEFYANT's Avatar
Even though that cam isn't huge, you will have PB issues. I know CTS-V have space constraints, so I would suggest twin 62's or so.
Old Sep 2, 2014 | 02:30 PM
Would like to stick to the single. Seen one in here trying to replicate his location. He is using an older tc78 .96 ar. Twins would be the easiest... wanting single tho
Old Sep 2, 2014 | 05:50 PM
Superman09's Avatar
LS1Tech Sponsor
The 7875 is a T-series, the TC series (60-series) is limited to the 68mm turbine wheel.
From our experience, most seem to run into excessive drive pressure on these 75mm turbine wheel units at the 383ci mark and up if you want to base it off displacement. I would recommend a turbo with a larger/higher flowing turbine wheel for sure on something with over 400ci (unfortunately this comes with the drawback of the turbo being physically larger as well for space constraints) Will the 7875 work, absolutely, just not as efficiently as it should and you will most likely see the effects of that in the upper RPM range.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Sep 2, 2014 | 06:00 PM
Hank Peabody's Avatar
pt88 $
Old Sep 3, 2014 | 10:16 PM
Funny you say that as I had a pt88... was going to locate it were the battery was, but under the car seems more promising. Its a heavy street gen1 V, so fast spool and compact is limiting on size.402 would be nice off boost Iim leaning towards 10.5 forged 6.0L ls2 with meth. Any draw backs of having the divided 1.15 ar housing?if I remove the divider I doubt it will give more power as the limiting factor is the 75mm exhaust wheel. Have a full 8.8 irs cs rear end... so if everything is rated about 1000hp...so a forged ls2 with say 15-18 psi should get me 900ish crank I would think. At a 10.4 static right now making 525 estimated with 18 percent loss puts me at 450rwhp, so take 10 degrees making it 475 ish x 2 15psi should yield me 900 I would think... maybe 750 rwhp.
im looking for 700 to 850. Rwhp.
Old Sep 16, 2014 | 01:21 PM
What about a comp 8079 tbb
