Boost Limit on 4 bolt heads
Old Sep 5, 2014 | 09:42 AM
ablakez28's Avatar
Originally Posted by rotary1307cc
Boost doesn't mean anything, neither does HP
Cylinder pressure (tq) is what is driving the head off.
control where and how torque is delivered and you are in good shape
Most problems stem from tuning issues whether it be detonation which creates insane cylinder pressure or it be boost delivery and timing
This sums is up. For the guys running higher #s on 4bolt heads with success what tuning tips do you have?
Old Sep 5, 2014 | 09:44 AM
LilJohn's Avatar
how much boost you run has no direct affect on head lifting. the intake valve has long been closed when that happens...
Like Rotary said... its all about torque... and where you make it...
Old Sep 5, 2014 | 10:14 AM
TINKRD's Avatar
Originally Posted by trans2000am
stock 317 heads, arp standard studs, ls9 gaskets, large frame turbo pushing 23lbs at 18 degrees of timing
exact same for me too. I was on a 408ci. 8.5:1CR, Pushing water is all in the tune IMO.
Old Sep 5, 2014 | 10:44 AM
mrstepheneades's Avatar
like a supra running 45psi with no head lifting issues. Keep things in the upper rpm?
Old Sep 5, 2014 | 10:55 AM
ScreamingL's Avatar
Changing Names
its whole combo as a whole not just one item. tune up is key, right fuel is key, IATs are key, ECTs are key, cam selection is key, rpm range is key
Old Sep 5, 2014 | 12:12 PM
stevieturbo's Avatar
They probably use bigger studs though.
Ive used close to 40psi on a Subaru before with no problems, but it used 14mm studs.
The CA625's can be bought for around $700 though.
Yes it's still expensive, but in the overall scheme of things not that much really. Certainly cheaper than 1/2" studs and supposed to offer similar clamping ability
Old Sep 5, 2014 | 12:15 PM
yoshgixxer's Avatar
Here is a link to them. You will see why few people run them in your average turbo builds when you see the price.
http://www.coloradospeed.com/arp-cyl...6-p-24550.html
Hollyyy shat. Thats expensive. I only have about
$550 in 1/2" studs and the machine work to tap and thread the holes.
Old Sep 5, 2014 | 09:04 PM
yoshgixxer's Avatar
Totaly agree. I only did it because i was building a brand new motor from the ground up and whats another 550 at this point, got the main caps pinned too. Im going to push it to 1200rwhp atleast.
Old Sep 6, 2014 | 05:16 PM
Sales@Tick's Avatar
Exactly!
Boost is just a number.
If anyone tries to tell you a certain amount of boost will blow your engine up or lift your heads, they don't understand how physics works.
You might have a 5.3L engine that needs 30psi to make 1000hp, whereas a 408 might only need 20psi to make 1000hp. Are you going to say that the 5.3 is going to lift the heads before the 408 because it needs more boost to make the same amount of HP? No!
Just like rotary said, it's torque production(cylinder pressure I.E. VE) and at what RPM it occurs that will lift the heads.
I am running 25-26psi and making well north of 1000rwhp with 4 bolt LSA heads, LS9 gaskets, stock diameter studs(custom aged) and an iron block.
My engine doesn't make peak torque until 6000rpm though, and this eases cylinder pressure at lower RPM's where if my engine made more torque at a lower RPM(I.E. more cylinder pressure) it would have a higher probability of lifting the heads.
Boost is a measurement of efficiency and how efficient your engine is in consuming/demanding air mass.
Old Sep 29, 2014 | 10:52 AM
Spectre86's Avatar
Originally Posted by CAMSTER
Factory heads hold a lot of boost specially the lsa /ls9 castings.
the shorter the stroke and the narrower the piston diameter the more boost allowance you will have with the OEM cylinder block and heads.
Worse heads for boost are Dart pro1 ls1/ls2 with 4" stroke they lift like an elevator, ouch Dart!
why are the darts so bad?
Old Sep 29, 2014 | 11:05 AM
asubennett's Avatar
Thin deck. Sort of like a stocker actually. I would say a Dart Pro head would be no worse than a 317 head.
AFR, Trick Flow, Mast etc all have really thick decks which help clamping.
Old Sep 29, 2014 | 11:15 AM
  #32
Look at Shawns mustang 5.3 record he just set. L33 making nearly 42psi with a gt55-88 and Chinese head studs with stock heads. Pure meth for fuel but that said, the heads will stay down with MEGA boost pressure if other factors are correct.
Old Sep 29, 2014 | 11:39 AM
  #33
Spectre86's Avatar
plenty of people seem to be running 800-900 wheel on 317s with no issue. are people just refering to darts being a bad choice for 1200+hp?
Old Sep 29, 2014 | 12:03 PM
  #34
Harry6674's Avatar
Is it worth it to go with cometic gaskets for twice to price of LS-9s? New 6.0 turbo build.
Old Sep 29, 2014 | 12:54 PM
  #35
Stick with GM gaskets...they're cheap and well proven
Old Sep 29, 2014 | 01:01 PM
  #36
asubennett's Avatar
Yes - Dart's have a bad reputation as an upgrade from stock heads. If you had no heads to start your build I would personally take a Dart head over a stock head. But obviously a trick flow head over a dart head etc...
I went 162 with my 317's recently but came across a killer deal on some Trick Flow GenX 225's and picked those up. Converting to 1/2 head studs as well. Mains are already pinned with ARP hardware.
I want to lean on this combo hard to see if I can squeeze 175 out the back door with the stock crank.
Old Sep 29, 2014 | 01:11 PM
  #37
Spectre86's Avatar
whats your setup?
Old Sep 29, 2014 | 02:56 PM
  #38
asubennett's Avatar
whats your setup?
Simple Eagle Rod ARP2000 rod bolt, Wiesco Piston, Stock Crank 370 Shorty.
Custom Comp Cam
Comp Magnum Rockers
Just switched to the Trick Flow 225 Heads (no times with these yet)
Pro Flo
Twin 70's
A/W IC
E85
Twin MagnaFuel 4303's
Bosch 1600 High Impedance
Holley HP
Reid Case Billet Glide
Neal Chance Converter
Old Sep 29, 2014 | 04:06 PM
  #39
NemeSS's Avatar
dang. i got a great deal on dart pro1 that i wanted to use on my 408.
i was under the impression they were an upgrade above stock castings.
i have a bunch of sets of 317s. but didnt really want to use em on something i have planned to run 25-30psi.
Old Sep 29, 2014 | 07:23 PM
  #40
ZGLASS's Avatar
stock heads are .300, darts are .500 or .550 i believe on the deck thickness. tfs/afr are like .650 and .750 i believe. I was pushing 23lbs on stock heads making peak tq at like 4500 and never lifted the heads. So Darts should do a bit better then stockers.
