procharger keeps blowing vacuum line?
Old Aug 30, 2014 | 11:16 PM
stanggreg90's Avatar
Default procharger keeps blowing vacuum line?
have a procharger on my trans am at 10lbs of boost with stock bypass valve, when i get on it the vacuum line by the throttle body keeps blowing off.
Old Aug 31, 2014 | 05:59 AM
stevieturbo's Avatar
Then secure it better with a clip.
Old Aug 31, 2014 | 07:43 AM
conan's Avatar
What hose keeps blowing off. Might have some PCV issuse to check out.
Old Aug 31, 2014 | 08:06 AM
Dino1's Avatar
Put a small wire tie on it and pull it down tight, simple fix.
Old Aug 31, 2014 | 11:33 AM
TrikeMike's Avatar
If you are talking about the OEM PCV system, you need to get rid of that setup and run a catch can with a breather. Any line that was a vacuum line from the factory is going to be pressurized in boost. And you don't want to be adding 10psi of boost to your crankcase.
Old Sep 1, 2014 | 11:16 PM
i have a catch can installed the vacuum hose from the blower to the intake keeps blowing off by the intake side i pulled the the hose today and it comes off real easy should i just put a wire tie on it?
Old Sep 2, 2014 | 07:59 AM
forcd ind's Avatar
what I have been using is the plastic lines they sell, might be for air brakes or something, but they have the fittings in 1/16 or 1/8 pipe fittings
you cut to fit, just push the line in the fitting
I think Procharger gives them to you in their kits
if its a pressed in fitting, then you cant use them
also if you can fing a barb fitting, they hold twice as good as the reg. hose ends
Old Sep 2, 2014 | 08:13 AM
ablakez28's Avatar
Zip tie/Wire tie works great for me.
Old Sep 2, 2014 | 03:17 PM
Ok i will try the zip tie thanks guys for your help
Old Sep 12, 2014 | 03:30 PM
Zip tie worked no more problems
