MSD 2 step with auto trans (Updated Track Results)
I have a video on FB, but no clue how to post it here. A buddy put it up.
You seeing any boost?
I tried the "soft" feature which drops individual cylinders vs a hard-cut, no difference in smoothness or amount of boost.
Here is mine:
https://www.facebook.com/video.php?v...type=2&theater
If the plugs are fouled out or old then it may be misfiring.
On my car the plugs that I had in it from the very first start up had to be changed out once we got it on the dyno. It wouldn't pull past 4500-5000rpm without popping and banging and misfiring.
Put fresh plugs in it and it was fine. If you're at a really low RPM you may just be hearing more popping from fuel in the exhaust than actual engine noise as the engine is not turning a lot of RPM.
Just a thought.
