Nitrous to Procharger Build
Old Sep 17, 2016 | 08:46 PM
  #81
DopeFedZ's Avatar
Originally Posted by SCott5
That's awesome setup man. I am on the fence so much about where to put my blower. Piece together a kit like you did or mount it down low like all the other ones. Really wanna do up top though.
It definitely looks cooler with it mounted on top. The only accessories Im spinning are the water pump and alternator. Had I known beforehand some of the issues I was going to experience I would have ran the alternator off the rear 4 rib section of the balancer. That instantly eliminated any belt slip and almost completely wrapped the belt around the balancer for the blower. No belt slip on the 8 rib setup.
Originally Posted by conan
Congrats man, those are some stout #'s with more left in the tank.
Thanks man yeah I don't want to get greedy right away but I know I will end up using the smaller pulley soon .
Originally Posted by The Alchemist
Have you driven the car at speed? I found without the center hood latch, the hood flexed a lot, and made me nervous, so I put a center latch on mine and it got rid of the shimmy shimmy shake.
Nice numbers by the way.
I've driven it around before and didn't notice anything with the hood. I'll ask someone to ride next to me and tell me what they see. Thanks man.
Old Sep 18, 2016 | 07:59 AM
  #82
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
http://shop.brutespeed.com/ATI-2GQSU...01-8-8-Rib.htm
ProCharger's new direct drive would of been a good way to go with had it been out when you built your car. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Sep 18, 2016 | 02:22 PM
  #83
charlie_gonzales's Avatar
DopeFedZ what crank pulley are you running? I know you mentioned it was 10% OD I was just wondering as to which pulley it was
I'd love to check your car out sometime
Old Sep 19, 2016 | 12:53 AM
  #84
DopeFedZ's Avatar
innovators west c5 10% o/d 8 rib balancer. let me know man Id meet up with you.
Old Sep 19, 2016 | 06:40 AM
  #85
ramairetransam's Avatar
Hey dopefedz do you think it would be possible in a post to make a write up of what parts you used to do this . I can see others wanting to go this way and while things are still fresh . Plus it would stop others from making some errors since you already learned . Great build . Your car makes me want to ta gfx , spoiler and rear bumper . I love these white hardtops mans.
Old Sep 19, 2016 | 08:20 PM
  #86
DopeFedZ's Avatar
I really didn't use anything special. Off the top of my head these are the things I purchased. I don't run any accessories other than the water pump and alternator. If you plan on running anything else you will probably want to buy some sort of flip drive to eliminate belt slip.
*ATI pin kit
*A&A C5 8 rib Procharger bracket.
*Innovators West 8 rib C5 balancer
*AEI CNC alternator relocation kit (runs the alternator off the 4 rib grooves on the balancer
*Powermaster 47802 alternator
*stock ls1 water pump
*Treadstone TRST9 intercooler
*twin walbro 450 pumps
*FIC 127lb injectors
Old Sep 19, 2016 | 08:34 PM
  #87
im shocked you dont have power steering , do you think you could run the vette accs and keep ac?
Old Sep 19, 2016 | 11:28 PM
  #88
DopeFedZ's Avatar
Really shouldn't be a big deal. All the accessories just sit a little closer to the motor when it is on the corvette belt line. My power steering has been gone for years. I didn't like the feel of it with skinnies when I used to run them. Now I'm just used to it.
