help me spec out a new ls build
I will be starting basically from scratch with a ls motor but I want to start collecting parts to build a motor over the next year. This will still be ran on e85. This is mainly raced with very little street use. I want to start off with an aftermarket block so I am not constantly worried about splitting the block in half or pushing coolant all over the place. I mainly want opinions on size and not so much on actual part selection. truck currently has a 98mm f trim 1.0 precision turbo. I know if i go any bigger i will need to change the wheel and exhaust cover or just sell this one and find one that fits the build a little better. Has a hughes performance glide in it with dedenbear case and all the goodies. currently has fast xfi. I will most likely stay with the fast and add an xfi box. plan on going with some type of mechanical fuel pump, either belt drive or cable drive.
Im looking to use a iron dart ls next block
do I go big cubes or keep the motor smaller and spin it?
big bore short stroke, big bore big stroke?
what static compression ratio with non intercooled , meth injection and e85
this is going to be a budget build, this will not have an crazy exotic parts in it, but it will be better parts then im currently running which is just a basic forged scat rotating assembly.
With the single I would not go big on cubes, stock stroke and a 4.125 bore would be the ticket. As far as heads and valve train go that is very dependent on budget and power goals in the future.
Most people spend 10 grand on a longblock 427 and a billet 94mm only to make 900 whp. Then guys make that with a stock junkyard 4.8.
I would go with the dart block, big bore and short stroke (4.8) crank. Rectangle heads. You'll be able to make huge power and spin it to the moon if you wanted.
I've been thinking about building another car for NASA and it'll use the same concept. N/A though.
It is awesome to see you still have and race this truck. I used to drool over the videos back when you had the 4.3 and T56!
