best turbo kit
Old Sep 25, 2014 | 11:23 PM
aAZz's Avatar
Default best turbo kit
Im looking to turbo my bone stock z28. Instead of going the h/c/i route i will be going turbo. Looks like the cheapest most complete kit is the on3 kit? Have been looking at the one that keeps ac. Anybody have any actual experience with the kit? Would like to see pros and cons as well as see how well they hold up to dd'ind. Other recommendations would be great as well but haven't found another bang for the buck kit then this one.
Thanks!
Old Sep 26, 2014 | 02:02 AM
spec_j's Avatar
hit up the search feature... i have spent months doing the same research and there are all many things to think of with every build. No one has the same wants or needs, so you can look through all the threads and see which ideas you want to go with.
Old Sep 26, 2014 | 06:09 AM
Heavy H.P.'s Avatar
What he said, a bunch of different things to consider so read read read.
Old Sep 26, 2014 | 06:30 AM
munn79ta's Avatar
i have the on3 non a/c kit. i was pretty impressed with the actual parts. the instructions for everything tho wasnt all that great. its pretty straight forward tho after you think about it. but its not just buy a turbo kit and go, you have to consider fuel and other goodies that you need. i went ahead and did cam,and all the other stuff. you will need valve springs imo. lots of hidden extra cost that will add up. my cost after everything was right around 4.5k. hope this helps you!! but you will love going turbo. good luck
Old Sep 26, 2014 | 08:14 AM
Rawr256's Avatar
I just finished up an A/C build, here is my build thread -
https://ls1tech.com/forums/forced-in...long-read.html
Loving it, takes a bit to get use to the burst of power when the turbo kicks in. My Toyo Tq's can't hold at all.
Old Sep 26, 2014 | 08:41 AM
munn79ta's Avatar
Rawr256 i literally have the same combo as you just only stage 1 from tick. i was wondering if anyone else had the only getting 5lbs of boost from the 7lb spring issue. did you ever get it on the rollers?
Old Sep 26, 2014 | 09:09 AM
aAZz's Avatar
Im just looking to be above 500rwhp with room to grow. Already have ls9 cam with upgraded springs. I kno i will need to address the fueling issues but plan on doing that regardless. I have been doing lots of reasearch and honestly haven't seen a more complete kit then this. It just seems to good to be true honestly and wanting to see the build quality and how its holding up in real life with people who actually drive their cars
Old Sep 26, 2014 | 09:47 AM
aAZz's Avatar
Examples i was looking for thanks!
Old Sep 26, 2014 | 10:06 AM
SM105K's Avatar
I would ask all of the turbo f body guys in Az.
Old Sep 26, 2014 | 10:07 AM
willizm's Avatar
Best in thread title but cheapest in body of text.
FYI
Best=/=cheap
With that said there are some decent affordable kits out there that will make good power. on3 and huron might be the two main ones to consider.
Old Sep 26, 2014 | 11:41 AM
aAZz's Avatar
I dont kno of anyone in az running the on3 kit
Old Sep 26, 2014 | 11:50 AM
Camaro9969's Avatar
Cheap and Turbo aren't two words that go together. May start off that way but your in for a treat lol
Old Sep 26, 2014 | 12:16 PM
SM105K's Avatar
Dont get your heart set on just the on3 kit. Ask around. If you have to stay stock of a couple extra months to get better stuff is well worth it.
Old Sep 26, 2014 | 01:12 PM
jrpimp00's Avatar
I have a Huron speed t4 kit that I converted to a t6. No problems and I see them every now and then in the classifieds for cheap
Old Sep 26, 2014 | 01:56 PM
VegasZ's Avatar
Huron Speed has a very good reputation around here and a lot of happy customers. They're coming out with a new AC retaining single turbo kit soon. You may want to touch base with them to explore that option.
Old Sep 26, 2014 | 03:57 PM
aAZz's Avatar
Im open to suggestions guys lol
I plan to upgrade the turbo but figured id atleast get the kit since seems like a good deal
Old Sep 26, 2014 | 06:46 PM
Rawr256's Avatar
Not yet, I could be wrong with the 5lb spring pressure, that is going strictly off what I get for map readings on my scanner. Haven't plugged it into a gauge or anything yet to get a true reading.
Depending on how my time goes this next weekend and my buddies at the shop I may take it over there for a few pulls and playing. FWIW I walked my buddies 475rwhp G8 GT Firehawk pretty bad, well after I launched from an idle that is.
Old Sep 27, 2014 | 04:41 AM
Superman09's Avatar
LS1Tech Sponsor
Always nice to see and hear good things in threads like these about us, greatly appreciate it!
We have our new V2 A/C Retaining kit to be released here shortly! It will absolutely be well worth waiting a few more weeks for to see! A few highlights:
*Fabricated stainless, v-banded extra thick .120 wall Manifolds *Retain A/C compressor and Alternator both down low in the factory location with factory brackets, no belt worries*
*Extra thick .120 wall, v-banded stainless crossover with our new Wastegate location that pulls from both banks individually. 2-piece crossover for easy installation around the A/C Components
*Clears T4 3" exit turbos and even Mid-frames such as PT88, BW S400 on the crossover with leaving the factory radiator in the factory position!
*Wastegate Re-route into down pipe is a standard feature, no extra fee!
*Wideband O2 bung in the down pipe is a standard feature, no extra fee!
*Stainless Steel hardware included!
*New updated intercooler mounts for easier installation
*Fits Factory front sway bar in the factory position, factory alternator down low in the factory brackets, Factory radiator/condenser in the factory position and much much more!
Expect an update on this kit from us in the next few weeks.
Jon
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Sep 27, 2014 | 10:32 AM
CaliboyTA's Avatar
cant wait for the v2 a/c kit
