LS9 Cam
Old Oct 3, 2014 | 05:30 PM
lsxmalibu's Avatar
I'll take the et over mph anyday. Cant really use my times as true test results. I only ran it 2 times and its untuned And was short shifting.
Old Oct 3, 2014 | 06:01 PM
dean85gt's Avatar
I made 672rwhp and. 735rwtq in a 5.3 with an ls7 cam on 18.5psi. Trapped 139mph works great
Old Oct 3, 2014 | 07:49 PM
LQ4 Tank's Avatar
LS7 or LS9? Just clarifying.. The two cams look identical however.
Old Oct 3, 2014 | 08:46 PM
dean85gt's Avatar
Its an ls7 but they are very similar
Old Oct 4, 2014 | 12:49 PM
LQ4 Tank's Avatar
What heads are you running?
Old Oct 5, 2014 | 11:56 AM
dean85gt's Avatar
799s. Its a stock longblock lh6
Old Oct 5, 2014 | 12:17 PM
Forcefed86's Avatar
Originally Posted by 69-chvl
So with 2 psi more boost you picked-up only 1 mph?
He also swapped form a 3.42 to a 3.23 gear at the same time. That would make a huge difference.
I trapped 153 on my ZR1 cam. But my setup only weighed 2900lbs.
Old Oct 5, 2014 | 06:22 PM
LQ4 Tank's Avatar
As long as this cam works and works well, I'm golden!
Old Oct 5, 2014 | 07:00 PM
stmz28's Avatar
I wouldn't use a ls6 or ls9 cam. With boost you are going to need better springs then the yellow or blue z06 springs. I would give give lil john a call he can get you setup with a cam, valve springs and push rods this way you wont have any valve train problems.
http://www.liljohnsmotorsports.com/
Old Oct 5, 2014 | 07:27 PM
LQ4 Tank's Avatar
If money wasn't a problem I'd be all over that, haha, trying to cut costs anywhere I can.
Old Oct 7, 2014 | 08:40 AM
Sales@Tick's Avatar
I would rather see you run a LS6 camshaft instead of the LS9 in a turbo application.
The intake valve close event is very late and IMO is not optimum for most combinations, if any other than its intended original purpose which is an OEM 6.2L positive displacement blower application.
Old Oct 7, 2014 | 09:13 AM
  #32
LQ4 Tank's Avatar
So in your opinion, what aftermarket cam would be the best for a turbo application? Not picky. And would like some lope if possible
Old Oct 9, 2014 | 08:44 AM
  #33
Sales@Tick's Avatar
I'd like to ask some questions about the combination first if you do not mind.
Bore and stroke/displacement?
Compression?
Cylinder heads?
Intake manifold?
Turbo used?
Trans?
Stall?
Rear gear?
Race weight?
Tire size?
These questions will get us going on the right track to specifying the right camshaft for your combination.
Old Oct 9, 2014 | 12:28 PM
  #34
LQ4 Tank's Avatar
Compression?
Cylinder heads?
Intake manifold?
Turbo used?
Trans?
Stall?
Rear gear?
Race weight?
Tire size?
Bore and stroke/displacement - 4.030 bore, 4.000 stroke/408ci, 6.7 liters
Compression - 8.5:1-9.1:1
Cylinder heads - L92's, or AFR 225/235's, haven't looked too much into them.
Intake manifold - Holley Hi-Ram because it looks friggin awesome and performs pretty good.
Turbo used - PT88
Trans - Built 4L80, and somehow beef up my transfer case.
Stall - Circle D 3,200-3,400 stall
Rear gear - 4.10:1 to 4.56:1
Race weight - Truck weighed in at 6,800 pounds with me in it on a scrapyard scale, will shave a little weight off but not much.
Tire size - 35's on the street, may find lighter rims and radials or slicks if traction is an issue, but that's what four wheel drive's for!
This is just my initial plan, I am always open to opinions!
Old Oct 14, 2014 | 12:32 PM
  #35
Sales@Tick's Avatar
Turbo used - PT88
Wow, that's a tank!!! Definitely going to need as much torque as possible. Top end HP is not going to make your truck any faster.
There will be a noticeable difference in the required valve events for a L92 head and for a cathedral port head. That will need to be decided upon before the camshaft is specified.
Old Oct 14, 2014 | 02:08 PM
  #36
LQ4 Tank's Avatar
Oh yes, haha, building it because how many other fast gas 3/4 tons are there? Not many.. I'll most likely stick with my 317 heads for now though. Wanting to just get the cam for now and at least pick up the power and sound cool until I get the rest of my parts
Old Oct 15, 2014 | 01:11 PM
  #37
Sales@Tick's Avatar
If you would like, shoot me an email to martin@tick-performance.com. We'll get a good cam picked out for you. Most likely end up in the low 220 duration range, possibly a 21x intake lobe.
Dang thing is heavy!
Old Oct 15, 2014 | 01:20 PM
  #38
LQ4 Tank's Avatar
Email is sent.
Old Oct 15, 2014 | 04:37 PM
  #39
samdogmx's Avatar
i've been 8.66 @155 with the ls6 cam, never tried the ls9 cam though
Old Oct 16, 2014 | 10:12 AM
  #40
69-chvl's Avatar
Wow
