LS9 Cam
Old Oct 1, 2014 | 08:10 PM
LQ4 Tank's Avatar
Default LS9 Cam
Is the LS9 cam a good/cheap route to go for a boost build? Going in my LQ4 that will have a Procharger eventually. Wondering if it's a good cam to throw in for a fourth of the cost of a custom grind cam.
Old Oct 1, 2014 | 08:47 PM
Hank Peabody's Avatar
The general consensus is that it is a turd in the lower rpm range. This is an interesting article http://www.carcraft.com/techarticles...n/viewall.html
Old Oct 1, 2014 | 08:55 PM
LQ4 Tank's Avatar
Yeah I scanned that article for numbers.. I've heard it takes some low end power away but the LQ4 doesn't have too muchlower-end power to begin with. Especially not at 7,000 pounds, that's why I want to go with a Procharger to make up for the lack of lower-end.
Old Oct 2, 2014 | 08:56 AM
Forcefed86's Avatar
I liked mine. I think it would have been even better on a blower car. The areas its down on power from the stock cam is usually below the stall speed of an aftermarket converter. I launched my car well above the "low end" power loss that folks complain about losing with this cam. It had a nice bump in power around 6 k on my 5.3.
If you want a cam that idles at 700rpm and drives like stock with a healthy bump in power over 6k id go for it.
Old Oct 2, 2014 | 10:36 AM
LQ4 Tank's Avatar
Did you see low end power gains, more around 3,500+? Want a little grunt down low too, my truck rarely sees 6,000 unless it's an all out race. Set to shift at 6,000 in tow haul.
Old Oct 2, 2014 | 11:41 AM
Forcefed86's Avatar
Look at the stock ZR1 dyno graphs for an idea on the power band. Probably not the best cam if you want it to come online at 3500. Your peak torque will most likely be where peak boost ends up. I doubt that will be at 3500 with a procharger. They need decent RPM to build boost.
My stall was rated at 3200, but I would see well over 4k on the trans-brake. So I was never really in the 3500rpm range.
What year 6.0? Are you already running a cam pickup on the front cover? If not the LS9 cam ends up ends up costing quite a bit more by the time you get the correct timing set/cam cover/ and sensors. (Assuming you’re on the factory ECU.)
I’d look into the aftermarket “truck” cams. Think my isky cam was $369 shipped. By the time I paid shipping/handling and bought the parts needed to run the ls9 cam I think I was around $220. For the extra $150 I’d just go with aftermarket stuff.
Old Oct 2, 2014 | 01:33 PM
LQ4 Tank's Avatar
2001 LQ4, completely untouched. I can get that cam real cheap off of my tuner and am fine with buying all the other little parts. The chart looks like a pretty steady climb up until that 6,100 peak, which I am fine with, considering it's the cheapest route availiable right now. Once I swap gears I'll be in the 4,500+ playing on the street so it should be fine. Right now running 3.73 gears and 35" tires. Just wanted some proof that this cam will work, especially when I'm going with boost in the future. Thanks guys!
Old Oct 2, 2014 | 02:17 PM
lsxmalibu's Avatar
love it for boost...drivability...for the price its a no brainer.
Old Oct 2, 2014 | 03:59 PM
LQ4 Tank's Avatar
Thanks man! I'm really looking forward to it. What all valve train components did you go with?
Old Oct 2, 2014 | 04:23 PM
69-chvl's Avatar
If you look at that magazine article they said that the LS2,3 and LS6 cams were pretty equal in power up top (apprx 80-90+hp) up top where the LS9 was up 112 hp but down as much as 40ftlbs down low. Seems like you might as well stick to an LS6 cam.
However, look at the Crane cams at the bottom of the test. The 210/218 was up apprx 100hp at 6500 with only a -10ftlb loss down low below 3500.
PS - that article botched the LS6's #'s - they had truck cam #s in that report. They did say however that the LS6 matched the LS2/3 up top for the most part.
Old Oct 2, 2014 | 05:20 PM
trevmust's Avatar
is a ls9 cam good for n/a drivability or no? if not i guess ill have to get a different one until i get a supercharger, i just would prefer everything be broken in before i bolt on the pure fun.
fyi im getting a gt9 lingenfelter, its a zl1 based cam.
Old Oct 2, 2014 | 05:37 PM
lsxmalibu's Avatar
I have the ls9 can and cheap ls6 springs. I had the ls6 cam...the ls9 is way better. Pulls harder. Idle and mpg is great
Old Oct 2, 2014 | 07:02 PM
LQ4 Tank's Avatar
Now that's what I wanted to hear!!!
Old Oct 3, 2014 | 07:57 AM
MonmouthCtyLS7's Avatar
Also heard the same thing from several members that ran both when I was going to run this cam...ended up getting a specd one from Martin though.
Old Oct 3, 2014 | 09:38 AM
Forcefed86's Avatar
Do you have any datalogs/timslips/dyno sheets etc between the 2 cams?
Martin from Tick told me I'd be better off with the OEM truck cam than the LS9 cam. And that the LS1/LS6 cams blew it out of the water performance wise. I found that hard to believe, but I had nothing to compare it to since it was my first build....
Old Oct 3, 2014 | 12:02 PM
lsxmalibu's Avatar
no...price wise its cheap and the best bang for the buck...but if you can find a used ls6-z06 cam for $100 buck use that too...
ls6 cam....3.42 gears 10.69 @ 10 psi
ls9 cam 3.23 gears 10.53 @ 12 psi
sure it was more boost, but it was also with higher rear gears....
Old Oct 3, 2014 | 12:25 PM
Forcefed86's Avatar
Thanks... have the trap speeds handy?
Old Oct 3, 2014 | 12:44 PM
LQ4 Tank's Avatar
Yeah the only thing making me go the LS9 route is working with a college budget. I really want some real world numbers with the cam (found one post where a guy made 326 to the rear wheels on a DynoJet with an LQ4 and T56, sounds extremely fishy to me) and not just the Carcraft article but I'm pretty set on it either way.
Old Oct 3, 2014 | 02:00 PM
lsxmalibu's Avatar
128 ls6 129 ls9
a guy I know uses the ls9 cam/ ls6 springs on his 2007 silverado l76 6.0, he puts down 575 rwhp with 13 psi..magnacharger
Old Oct 3, 2014 | 02:48 PM
69-chvl's Avatar
128 ls6 129 ls9
So with 2 psi more boost you picked-up only 1 mph?
