Need help with twin turbo set up.
Turbos I am kicking around are sized as follows. (50 mm .63ar) or (70mm .84ar)
What is the max output of these on a 5.3? The engine is currently making 358whp 339wtq on a Dynoject. Set up is going in a 2247lbs Factory Five GTM. Not a drag car, street and occasional autocross only. Which would you go with and what is the capabilities of these two very different turbos.
Any direction would be greatly appreciated.
Check out some of the sites sponsors also.
You should be looking for turbos in the 58mm to 62mm.
- Turbine Specifications
.64 A/R
.76 Trim
- Hybrid Journal Bearing
- Oil Cooling only
- Compressor Wheel
-8 Blade T4 Design
-0.50 A/R Cold Side
-Ind: 52.76 mm
-Exd: 75.46 mm
-trim: 48.9
-Turbine Wheel
12 Blade Design
0.58 5-Bolt Standard Hot Side
Ind: 57.75 mm
Exd: 73.35 mm
Trim: 61.9
