5.3 Turbo Build
Old Nov 16, 2014 | 05:47 PM
  #81
85_Z28's Avatar
Got a name for the build?
Old Nov 17, 2014 | 05:50 AM
  #82
jay_rich's Avatar
My current that Im building is the white one which I am taking more time on and trying to keep everything on the car stocck (sheet metal wise etc) This one is done with a ebay GT45 which is physically a pretty big T4 turbo. Similar in size to the Borg T4 S475 which I will be swapping to as soon as the GT45 lets me down.
My old 370 T6 flanged turbo is the red/black engine bay (which I cut the entire rad support out and welded in new bars, shaved the firewall after the picture since I spun a bearing and yanked the motor and started making it more into a drag car then decided to part it.)
Jay
Attached Thumbnails 5.3 Turbo Build-20141114_213702.jpg   5.3 Turbo Build-crossover-tack.jpg   5.3 Turbo Build-dsc01375.jpg
Old Nov 17, 2014 | 09:11 AM
  #83
85_Z28's Avatar
On your last pic, how close to the hood was your intake setup? And got of the motor mounts?
Old Nov 17, 2014 | 09:41 AM
  #84
jay_rich's Avatar
Not totally sure but I had to run a 4" cowl. I may have been able to get away with 3" but found it local. I ran Adapter plates on that setup. Which I dont recommend. PITA. On the current car I'm running spohn mounts with 4th gen poly's on the block.
If you go that route the only tip I can give is when installing the mounts on the K-memeber with 10mm bolts Push the mounts as high up as they go then bolt them in (spohn drills the mounts 1/2 clearance but the K-member is only 7/16) . It lined up decent. I had to use a pry bar and pound in the one bolt in the mount. But I also had 1/2" bolts. I would recommend going down to a 7/16 to give some clearance.
Jay
Old Nov 17, 2014 | 10:50 AM
  #85
85_Z28's Avatar
Im thinking im gonna run into clearance problems at some point now. My intake setup is a lot taller and I am running a 4" cowl too. Motor mounts I was thinking of going with those but hadn't decided.
Old Nov 17, 2014 | 11:42 PM
  #86
85_Z28's Avatar
http://www.ebay.com/itm/161483679045
Really liking the black set of valve covers, your guys opinions?
Old Nov 28, 2014 | 06:03 PM
  #87
85_Z28's Avatar
Okay I'm thinking I want the plate style motor mounts. Anyone have some pics on a setup for a 3rd gen Camaro?
Old Nov 28, 2014 | 09:15 PM
  #88
85_Z28's Avatar
Also I just found a On3 Performance 76mm turbo locally for $150 but possibly needs rebuilt. I think I could talk the guy down though. Is it worth getting this turbo? And can any upgrades be done to it? Or should I just buy new?
 Michael S. Palmer
Old Nov 28, 2014 | 09:51 PM
  #89
1969x11's Avatar
Pass on3 turbos are in my opinion run till they quit and then throw away, yes I'm running one now.
Old Nov 28, 2014 | 10:12 PM
  #90
85_Z28's Avatar
So these really aren't rebuildable turbos?
Old Nov 29, 2014 | 07:13 AM
  #91
1969x11's Avatar
I'm sure they could be rebuilt...but if it cost 300 bucks to rebuild a 350 buck turbo is it worth it? Not to me anyway.
Old Nov 29, 2014 | 09:55 AM
  #92
85_Z28's Avatar
Yeah true, my only thought to rebuild it was maybe there were upgrades for it that I did not know about.
