regulator question
Old Oct 21, 2014 | 06:49 PM
Blacklavender79's Avatar
Default regulator question
I am running the holley dominator fuel pump 12-1800 with a -10 feed to a quick fuel e85 blowthru carb and a -8 return. I called aeromotive today they recommend the 12304 regulator which is a -10 feed -8 return and two -6 outlets, ive seen poeple on other forums say they had a hard time regulating pressure low enough with that regulator. Some people run the 13202 which has four -6 outlets. I would be plugging two of them anyway for the carb setup. Anyone have any insight or similar setup that could steer me in the right direction? Cant see the four outlets making a difference in the setup, if anything i would be considering running a -10 return to keep the pressure down if the reguator struggles to do so.
