FI or nitrous
Old Nov 9, 2014 | 09:04 PM
  #61
chevybayboy's Avatar
Originally Posted by conan
Have you found a head unit yet ?
Yes got a d1sc should be here tomorrow . Also I'm going to home port my 317 heads is the a certain valve I should go with or would the stock be ok?
Old Nov 10, 2014 | 08:25 PM
  #62
This came in the mail for me today!!
[ATTACH]476557[/ATTACH
Old Nov 10, 2014 | 08:28 PM
  #63
Got some work done today
Think I'm moving along quickly
Old Nov 10, 2014 | 08:30 PM
  #64
35thsscamaro02's Avatar
you pickup a blower crankpulley yet?
  #65
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Thumbs up
Originally Posted by chevybayboy
Thanks for all the help today bob . Got a list on everything that I need I'm really not that far off from getting everything on I'm about 2k away in parts thanks everyone I will keep this thread updated on progress when I start and take lots of pics
You're welcome. Thanks. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Nov 10, 2014 | 08:41 PM
  #66
conan's Avatar
Stock valves will be fine. Just make sure you have a good dual spring in there.
Blower looks good all polished up
Old Nov 10, 2014 | 09:14 PM
  #67
Came with 3 different pulleys for the blower it's only a 6 rib I'm debating on keeping the 6 rib on going to 8. Most likely 8 rib set up
Old Nov 10, 2014 | 09:21 PM
  #68
Lol needs a bit of cleaning up. I'm almost there having the car I wanted since I was 14. And the way I want it. She has never let me down. Never not started for me or anything. Sorry having an emotional moment about my car lol.
I'll probably mount the intercooler and re locate the cruise control. Finishing pricing everything like the fuel system and gauges.
What 50/50 mix of water meth do you guys recommend ?
Old Nov 10, 2014 | 09:22 PM
  #69
I'm going to throw some btr springs and a tick custom cam
Old Nov 11, 2014 | 08:20 AM
  #70
conan's Avatar
Sounds like a good choice for your cam and valve spings.
I run a 50/50 meth/water mix, nozzle is mounted about 14" from the inlet air temp sensor and is set to come on at 4psi.
I would also recommend going with the 8 rib set up. Save your self the trouble later.
Old Nov 11, 2014 | 08:37 AM
  #71
Ok cool thanks
Old Nov 11, 2014 | 05:57 PM
  #72
Ok how can I tell if the unit I received is I p1 or d1? I called ati with serial number he said it cam back as a p1 us there a possibility it was upgraded? Because it's stamped as a d1sc
Old Nov 11, 2014 | 06:07 PM
  #73
LS1Tech Sponsor
Attachment 476729
It could of been upgraded, but ProCharger should have a record of that. Does it have a straight blade or a curved blade impeller? Bob
__________________
Old Nov 11, 2014 | 07:58 PM
  #74
Not sure if it's straight or curved I'll post another pic of it.
Old Nov 11, 2014 | 10:53 PM
  #75
Ok I did some research it's a d1sc
Old Nov 12, 2014 | 05:54 AM
  #76
LS1Tech Sponsor
Attachment 476754
Bob
__________________
Old Nov 20, 2014 | 09:08 AM
  #77
Heads came in so I disassemble them so I can start porting them these are before pics I'll show pics after when I'm done. Also the Trick flow spring compressor tool best tool I've used so far
Old Nov 20, 2014 | 08:45 PM
  #78
Started working on exhaust ports. Did the blending got 4 more then I will start sanding and making everything even. Then high polish the exhaust ports
Old Nov 26, 2014 | 10:20 PM
  #79
Ports coming along of course cam does no real justice just a little more work and I'll start polishing them
Old Nov 27, 2014 | 12:27 PM
  #80
Ports are coming along nicely
