FI or nitrous
Old Oct 24, 2014 | 12:43 PM
chevybayboy's Avatar
Default FI or nitrous
What's going on fellas I have a chance to get a supercharger kit at a pretty decent price the think is I'm set up for nitrous I never sprayed don't have the kit installed or anything.
I have a 383 stroker forged with flat top pistons and milled heads. I was thinking changing heads to 317 and run a thick head gasket to lower compression . And changing my cam to a FI cam. It's a twin intercooler kit minus injectors fuel pump and head unit .
I could sell my nitrous stuff to replace the stuff I would need for this what do you guys think I should do?
Old Oct 24, 2014 | 03:26 PM
SwampWS6's Avatar
Well this is a no brainer........FI! ........Even more since you posted in the FI section!
Old Oct 24, 2014 | 04:51 PM
tnmotown's Avatar
I'm going to tag along in this thread….
I also want to add a nitrous kit to my car, since I've already done it once. But now I'm leaning towards jumping into the FI world. It would be turbo though, not a supercharger.
OP, I say go forced induction and let us know how you like the change lol.
Old Oct 24, 2014 | 05:05 PM
35thsscamaro02's Avatar
I sprayed nitrous 2010-2012 really enjoyed it but honestly i was spending 120 a week on nitrous for most of the year. I hated my car na. made 424 na and 590hp on the bottle. I said screw it and bought d1 procharger ran that 2012-2014 now I sold that and am going big single turbo. lol I would for sure say forced induction is the way to go if you can afford it.
Old Oct 24, 2014 | 05:13 PM
tnmotown's Avatar
Exactly, I wouldn't want to keep spending money on bottle refills.
Going FI is more costly, but the power is there when you want it, and all the time.
Old Oct 24, 2014 | 05:38 PM
Kmspeedie's Avatar
only thing is once you go boost....you can never get enough, you get used to the power your at, and then want more..FI is definately better imo, but get ready to always want more haha
Old Oct 24, 2014 | 06:31 PM
Thanks for the input. So do you guys recommend me changing the Pistons or would I be ok with that setup running like 8 lbs of boost
Old Oct 24, 2014 | 06:38 PM
How much power were you putting down? And what was done with motor
Old Oct 24, 2014 | 07:31 PM
made 668rwhp on 11lbs on stock bottom end. Turned it up to 16lbs never dyno again but it was fast lol. started smoking and parked car sold motor. probably 30 bottles through that engine easy. Ran the blower for two years beating on it daily. like i stole it for real. lol
Old Oct 24, 2014 | 08:37 PM
What was your compression?
Old Oct 24, 2014 | 08:57 PM
10.1:1 I believe I ran 93 octane and tons of meth. 75/25 meth/water
Old Oct 24, 2014 | 10:24 PM
DEFYANT's Avatar
Do both lol. Run a D1SC with an Aster and FMIC, and then a 100 shot on top of it!
Old Oct 24, 2014 | 10:26 PM
conan's Avatar
What compression are you at now ? What all is included in the used kit your looking at ? J-bracket, radiator shroud, crank pulley ect ?
Old Oct 24, 2014 | 10:32 PM
Right now with milled 243 heads I'm at 11.1 with the 317 and a thicker gasket should get me back down to around 10.3 right? ..the kit includes everything minus the blower injectors and blow off valve for $850 twin intercooler setup. Is it worth it?
Old Oct 24, 2014 | 10:50 PM
conan's Avatar
So you do get a J bracket and the plumbing kit procharger fan shroud ?
What size intercoolers ? 3.5" or 4.5"
Are your pistons completely flat of do they have some valve relief in them? I get 10.5:1 compression with flat tops, 317's and LS9 gaskets.
Old Oct 24, 2014 | 10:57 PM
Yes j bracket and piping . They are the 3.5 intercooler . Yes the have -3 reliefs
Old Oct 25, 2014 | 08:56 AM
willizm's Avatar
Since this is the FI section i'm gonna say go Nitrous. Yep, definitely Nitrous.
Old Oct 25, 2014 | 09:42 AM
conan's Avatar
With -3cc reliefs, 72cc 317 heads and ls9 head gaskets I got 10.2:1 compression. Right where you want to be foe a street driven car. My last motor was low compression and it was a dog out of boost. My new 383 is a 10:1 compression, it is soooo much better to drive in all part throttle conditions again. Heads and gasket would be the only thing I would change. Everything else being forged your bottom end should be plenty good to the 700+ hp range.
Back to the used kit. Is the J bracket in this used kit just stock or does it have the ASTER or SDCE spring tensioner on it ? What head unit are you thinking about D1 of F series ? Power goal in mind ?
Reason for all of my Q's is because the 3.5" coolers are the smallest of them all and they loose their efficiency once you start to turn up the boost. I also wasn't a fan of all the plumbing that goes in to the twin cooler kit, it was a very cluttered mess. That was one of my reasons for selling my twin plumbing kit and going to the front mount cooler.
Old Oct 25, 2014 | 11:20 AM
It's the stock j bracket . No problem all the input is wanted. Really thanks for the info. I plan on using the d1sc. And it's actually $850 for everything he going to meet me intown. . So is this a good deal?
Old Oct 25, 2014 | 12:55 PM
Ok so I got the kit. Let the fun begin!!!!!
