Water injection before intercooler? good? bad?
At least injecting pre-compressor, actual flow/pressure will remain a known. And this also ensures a good spray pattern because of consistent high pressure
When injecting into the boost pipes, this will actually be a variable.
Richard did a test showing how much flow and pressure drop when trying to inject large quantities of fluid into a high pressure area, and it was quite dramatic
Once some of the pumps were trying to feed say 2 moderate size nozzles, pressure dropped off dramatically. Combine that with boost pressure acting against the pump and you might see actual spray pressure down to 60-100psi range when you think it's upwards of 160psi
No, it will only maintain 160psi to inject liquid when you are injecting to atmospheric pressure, ie pre-compressor, and when the pump has enough flow ability to keep up
If you inject into a boost pipe, you have boost pressure acting against the pump regardless, so less pressure actually gets used to inject water.
ie 160psi against 30psi boost only means 130psi to inject water, again while pump is able to maintain flow to support that pressure
As flow demand goes up, pump ability will still suffer and pressure will drop. It's no difference to a fuel system struggling to maintain pressure when the pump cannot keep up.
You repeated exactly what I said. Yes, I know that it's a pressure differential, so it's pressure at the nozzle, minus (or add) the pressure in the intake charge pipe. That's why the chart I posted is important. Instead of just guessing how much to inject, you have to actually use some math and do the calculation based on injector flow rate, what % of total flow rate you want to supplement with water/meoh, and boost pressure.
These pumps that Aquamist use are quite stout and able to maintain 160psi even at very high flow rates.
So instead of just guessing flow rates, and nozzle sizes, you use the calculator at this link.
http://howertonengineering.com/tech-...ating-jetting/
I have no concerns at all that the pump can keep up and maintain 160psi at the fast acting valve.
Even it struggled to maintain pressure once flow rates got high. The smaller 160psi pump will obviously perform worse.
If injecting water, flow rates will probably be low-moderate anyway so no worries. But with those injecting 100% meth, they will be demanding huge amounts of flow.
Almost all the pumps used are the Aquatec or Shurflo anyway, so really cant see there being huge differences in performance in that respect no matter who's kit people are using.
If you spray onto or near the sensor...there is bound to be some error due to spraying cool liquid directly onto the sensor. Some may evaporate, some will not.
If you can measure air temp as close to the intake valve as possible you'd get a more accurate picture, but then it would be almost impossible not to have some error from heat soak due to sensor location.
Ultimately it isnt super critical about accuracy though as long as the readings are consistent and reliable
This can easily be proven when comparing the power output of a non-intercooled alky injected setup VS an intercooled setup at the same boost levels. Even with a small pressure differential across the IC core, the intercooled setup will make more power. I’d look at EGT temps if you wanted to push a meth/water inj. system.
If your dead set on it, I'd just run the 50/50 mix the dealers sell at 15Gph Pre TB and 2 GPH pre turbo. 300psi pump. Have it kick on at 10lbs or so...
Most of the intercooler benefit comes from temperature differential so if you spray just before the intercooler, you get the benefit of the spray but make your intercooler less efficient since there is less of s temperature differential. If you got the intake charge even colder than ambient with the liquid injection before an a2a intercooler, the intercooler would actually heat the intake charge.
If you spray just before the compressor, you increase the compressor efficiency by ostensibly decreasing the tolerances through injecting a (mostly) non-compressible fluid.
If you spray just after the intercooler, you have more time for the meth to evaporate and cool the intake air and distribute into the air charge evenly.
Meth also gives you some octane cushion.
Water injection does a great job of preventing hot spots in the cylinder which can be the cause of pre-ignition
I have a supercharged (centri) jet ski with a 1.8L 4 cylinder pushing about 16-17lbs of boost. I have an aftermarket water to air intercooler as well and an unlimited supply of freshwater cooling the intercooler. Water temp right now is around 80F.
During a top speed run, I can see that my RPMs begin to drop. I sometimes lose 200-300rpm throughout a pull. I believe this is being caused by IATs rising during the run. In the jet ski world, this equates to 2-3mph. Also, since it's a centri blower, as RPMs fall, so does boost, just compounding the problem.
To try to help with this problem, I've thought about adding water injection. I have an infinite supply of water and I have 100+ psi available from the jet pump. If injecting a small amount of water into the engine would help with the heat fade I'm seeing, all I would need would be a water filter and a nozzle/solenoid setup. It would not add much weight or complexity to the ski.
Right now I'm making somewhere around 350hp. If I could keep this heat fade away by using water injection, it would certainly be a cheap way to gain some good/more consistent top end.
So my question, will injecting water alone provide enough of a cooling benefit to keep my IATs down and lead to less heat fade? The IAT sensor is in the intake manifold. Where would be the best place to spray?
Thanks,
Adam
