C5 turbo kit
Old Nov 7, 2014 | 12:28 AM
ghost-1's Avatar
Originally Posted by HolyShiznit
Strongly advise against the Hinson kit. It has massive fitment issues and you essentially have to custom make everything else. I had one, took it off before I even fired up the car and sent it back.
IMO: you wont find a turbo kit for a c5 for $3k and even then it wouldnt include everything necessary to run it. UPP's kit is great for the price!
I had the hinson kit of my c5 with a 76mm turbo and it was a tight fit there was a lot of custom work that I had to perform. But I was able to fit an 88mm turbo in the car with modifications. So if you have to ability you could just purchase their hot side for a decent start. But if someone else is making a kit I would suggest that if you don't have the ability to modify the hinson kit.
Old Nov 7, 2014 | 06:42 AM
oscs's Avatar
Originally Posted by ZGLASS
not doing a turbo c5 for 3k. Not a good one anyway. If you did all the work yourself and used super budget parts maybe. But it will not perform like a well built setup. If your looking for budget boost used blower kit.
Maybe you can't buy a kit but I could certainly build one for much cheaper than 3k. It would be nice if someone sold a kit minus the welding
Old Nov 7, 2014 | 07:10 AM
oscs's Avatar
In a perfect world people dont pay for labor to weld all the materials or the R&D I guess :p
Yeah yeah I get it lol. I was just curious if someone made a Hotside kit or something out there of decent quality for not 6k. Truthfully I knew the awnser to my own question but it never hurts to ask.
Old Nov 7, 2014 | 07:15 AM
slowride's Avatar
This is true, but guys like us need to report back after a bunch of miles/years and see how those kits are holding up I haven't had any issues with mine yet but it's only been 600 miles or so. My twin turbo kit including the turbos, intercooler, pipe, etc was way under $3000 in parts with hookups, but it wasn't exactly a little amount of work to build it on a C5 that's for sure. C5/C6 vettes are not an easy turbo kit to fab up if you keep all the AC, PS, etc, etc.
If you are not into fabbing parts and/or don't understand turbo stuff well, stick to a simple blower kit.
Old Nov 7, 2014 | 02:48 PM
ajrothm's Avatar
I would DEFINTELY wait for the Huron TT kit.... I've seen the prototype...its killer.. Definitely gonna be the best option out there for C5s.
Not gonna get it for $3k though... not even close.. Once you see it, you'll know why..
Old Nov 7, 2014 | 03:08 PM
rkreigh's Avatar
good, fast, cheap
pick any 2
the UPP is the "bargain" at 6k and it's half the TTiX
APS is gone, and STS is 7k or so
if you want a cheap turbo c5, buy one done
seeing good cars go for 25k on a regular basis
building a turbo c5 is NOT cheap
Old Nov 7, 2014 | 03:09 PM
Superman09's Avatar
LS1Tech Sponsor
Not only will it be able to be the most powerful kit on the market, but it will also keep all of your accessories meaning no deleting parts, relocating components to fit turbo parts, etc! Did I mention nothing else out there to purchase will be able to compete in terms of power as well!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Nov 7, 2014 | 04:03 PM
sbcgenII's Avatar
Where are the pics?
V-seriesTech's Avatar
I ended up with a PTK kit, which people have made copies of, and are now available online or websites for decent pricing. We have 2 original ptk setups, and one of the "knock off ones". We haven't done anything more then take the headers out of the box and, they honestly look pretty good,..and are also stainless. Now, we haven't bolted the kock off kit to anything so, I do not know how fitment is. Seems to bolt up to our foam block and foam heads no problem though. One of these kits, might be an option for someone.
Some things to consider though, if you go that route.
Alternator relocation,..as well as needing a mini starter
removal of factory washer jug, and coolant reservoir
EBCM to be lowered
radiator to be raked
I would suggest a LOT of heat treatment on inside of hood,...maybe even a vented hood to assist.
Other then that....lots of small changes here and there.
If you have fab skills....make radiator flat forward facing or make it face down...and build turbo or turbos above it.....or if you lay radiator flat against frame rail place turbo(s) there. Nothing is cheap.... I went the blower route but...honestly, unless you go with an 8 or 11 rib and a trick bracket design....you'll have problems trying to make power on a centrifugal blower..not to mention the cost in needed exhaust to add to the cost.
I like my PTK kit but, it isn't for everyone. If you neeed help with tubing(sourcing)...lemme know if you can't find anyone from here to help you out.
(and the new huron speed kit will be badass)
Old Nov 7, 2014 | 04:05 PM
oscs's Avatar
Originally Posted by rkreigh
good, fast, cheap pick any 2 the UPP is the "bargain" at 6k and it's half the TTiX APS is gone, and STS is 7k or so if you want a cheap turbo c5, buy one done seeing good cars go for 25k on a regular basis building a turbo c5 is NOT cheap
Your suggestion to finding an affordable option to turbo a C5 is buying a 25k car? I'm well aware of what it takes to build a turbo car and I'm familiar with C5's I never said it was going to be "cheap" I just wanted to see what was out there as far as kits where concerned.
Old Nov 7, 2014 | 04:06 PM
Superman09's Avatar
LS1Tech Sponsor
Our kit is in the very early stages so I don't want to release any photos yet. Give it a few weeks and we will have some
__________________
Old Nov 7, 2014 | 04:11 PM
  #32
oscs's Avatar
Originally Posted by V-seriesTech
I ended up with a PTK kit, which people have made copies of, and are now available online or websites for decent pricing. We have 2 original ptk setups, and one of the "knock off ones". We haven't done anything more then take the headers out of the box and, they honestly look pretty good,..and are also stainless. Now, we haven't bolted the kock off kit to anything so, I do not know how fitment is. Seems to bolt up to our foam block and foam heads no problem though. One of these kits, might be an option for someone. Some things to consider though, if you go that route. Alternator relocation,..as well as needing a mini starter removal of factory washer jug, and coolant reservoir EBCM to be lowered radiator to be raked I would suggest a LOT of heat treatment on inside of hood,...maybe even a vented hood to assist. Other then that....lots of small changes here and there. If you have fab skills....make radiator flat forward facing or make it face down...and build turbo or turbos above it.....or if you lay radiator flat against frame rail place turbo(s) there. Nothing is cheap.... I went the blower route but...honestly, unless you go with an 8 or 11 rib and a trick bracket design....you'll have problems trying to make power on a centrifugal blower..not to mention the cost in needed exhaust to add to the cost. I like my PTK kit but, it isn't for everyone. If you neeed help with tubing(sourcing)...lemme know if you can't find anyone from here to help you out. (and the new huron speed kit will be badass)
This is the type of awnser I was looking for. All the little crap involved is not an issue. I live and breath the little ****. It's the time it takes to engineer the piping etc that is the major PITA for me. I'm trying to talk him out of a novi 2000 but he's pretty set on it becuase of how easy the setup is. If I could find a decent price on pre fabed hot/cold piping and proven intercooler than I could get the rest knocked out in no time.
Why do you think he will have trouble with the centrifugal setup?
Old Nov 7, 2014 | 04:53 PM
  #33
For me, my issues where the quest for more power but, I needed to buy pullies(more ribs) and brackets to do so. It ends up being a lot of money, here and there to do these upgrades to blower setups. Now, if he is cool with some box stock 6 rib, wants to make 600-700rwhp and never more(i know you can make a ton of power on a centri, thats not the argument) then maybe he'll be fine. For me, I bought one bracket,...bought another...ended up bracking idler pullies off the front of the motor due to MASSIVE tension from a short/tight belt fit(trying to counter the slip).
I have been building a friends C6...he wanted a blower...so I am doing an F1X setup...we had to buy a flip drive setup(dallas perf).... then we had to get another bracket(ecs).... even THOSE things, had to be modified to fit the car....as nothing was a direct bolt on. People say blowers are cheaper but,...not in my experience.
Bracket technology is better today then when I had a blower on my car to be fare but...to me...i don't think I would ever go the centrifugal route again....on my car, or even for a friend. Then the DRAG on the motor.....to spin the blower drive/compressor...vs a turbo, and it's free spool setup. I picked up a ton of power vs the blower setup, going to turbocharged power.
I also didn't like peak boost at peak rpm. For street racing,..which is what I was primarily doing with the car then...the turbos work WAY better under the curve. I love blowers but, equally hate them.
Old Nov 7, 2014 | 08:40 PM
  #34
tonypaul's Avatar
Is he planning on running the '98 ecu or upgrading the engine management?
Old Nov 7, 2014 | 10:13 PM
  #35
rkreigh's Avatar
no, you can find a TT C5 for 25 k, sell the stock one, and the delta will be MUCH cheaper than building one.
I like the TTiX kit, but it's over 10k
Old Nov 9, 2014 | 06:43 PM
  #36
JDS99's Avatar
You must have got a deal on those parts because I know you used turbonetics snails, Tial gates, stainless pipes, etc..
Unless someone is going to build it with free labor and knockoff parts, no way to do a TT kit on a C5 for 3k or under. Definitely no lie in C5/6 vettes not being easy to fab up a front mount kit on. Unless you kill accessories, and total the car by cutting the frame. The C5/6 frames are narrow.
I agree, I would wait for the Huron kit too. But i'm a bit biased
Guess this is my virgin post on tech
Old Nov 9, 2014 | 07:00 PM
  #37
oscs's Avatar
Originally Posted by JDS99
You must have got a deal on those parts because I know you used turbonetics snails, Tial gates, stainless pipes, etc.. Unless someone is going to build it with free labor and knockoff parts, no way to do a TT kit on a C5 for 3k or under. Definitely no lie in C5/6 vettes not being easy to fab up a front mount kit on. Unless you kill accessories, and total the car by cutting the frame. The C5/6 frames are narrow. I agree, I would wait for the Huron kit too. But i'm a bit biased Guess this is my virgin post on tech
For the record it doesn't have to be a TT kit. Anyways the guy bought a novi 2000 so yeah.
Old Nov 10, 2014 | 07:57 AM
  #38
slowride's Avatar
Was going to say "look at the new guy talking all that stuff" hehe. Anyway the new Huron kit should be the **** that's for sure. A t4 setup will let people build what they want and not have the restrictions t3 turbines place on 1000+ hp numbers.
Old Nov 10, 2014 | 11:24 PM
  #39
BLWN1's Avatar
I may have 3,000 total in mine. Be close. Billet s480 front mount. Need a2a and wag/bov. Just gotta pick them up.
Old Nov 12, 2014 | 12:03 PM
  #40
That's cool, at least he bought something. Never know until you experience it.
