Catch can or Not?
Old Nov 11, 2014 | 02:23 PM
oscs's Avatar
Originally Posted by MIGHTYMOUSE
there are lots of people that are happy with lots of different things, that's what makes the world go round. some people want the benefits or legality that a pcv system provides, some don't care, or just have other priorities. I side with all of the OEM's that if at all possible it should be kept to extend oil and engine life. I looked for emails and could not find, sorry for the delay but I would be happy to answer any questions you have anytime. mightymousesolutions@gmail.com
Different strokes for different folks I suppose. Keep you eyes open for an email. I'd be curious to see what you think about the setup.
Old Nov 11, 2014 | 04:21 PM
SpeedJunkee's Avatar
Originally Posted by oscs
I hear you man. If you look back a few posts another member posted a picture of what he did. I'm not sure what your valve train consists of but regardless of what evac system you choose you need to have some type of baffling system to prevent oil from being sucked either into your catch can or being dumped into your exhuast. I've seen a few member on here that have filled their cans in less than 300 miles becuase they did the same thing you did. They welded bungs with out baffles in a spot that was susceptible to splash/pick up.
My car was supercharged with the catch can and its current bung in the valve cover (no baffle). I ran close to 8,000 miles with it that way and let out very minimal amounts of oil from the catch can. Before the catch can, I ran breathers on the valve covers. I knew I had a lot of crankcase pressure because I would find a oily film under my hood near the spot of where my breathers were.
Now I am swapping to a large turbo (don't know how that will effect the crankcase pressure). Again, I like the idea of venting it into the exhaust if its not in excess amounts to burn the oil, smell it burning or come out the tail pipes. Not sure if since my catch can never was full that this won't be the case or not. I wish there were a way to tell without just going forth with the setup. I could keep the catch can, but I know I will be limited on room with the large turbo.
Old Nov 12, 2014 | 11:11 AM
rotary1307cc's Avatar
Lol, have you ever heard of emissions? Possible that is the reason it is incorporated into the OEM design
Engine life?Pre emmission diesels ran a million miles plus with draft tubes lol
Old Nov 12, 2014 | 12:31 PM
MIGHTYMOUSE's Avatar
so, then you are agreeing to exactly what i said. "some people want the benefits or legality that a pcv system provides, some don't care, or just have other priorities"
Old Nov 12, 2014 | 01:04 PM
JoeNova's Avatar
Restricted User
I too would run a catch can in between the valve cover and the check valve/fitting in the exhaust if I went with this system. The exhaust becomes your source of vacuum, it still doesn't (always) solve the problem with the oil. At low exhaust heat/velocity situations the oil won't burn off quickly enough and could pool and clog up chambered mufflers.
Old Nov 12, 2014 | 01:54 PM
oscs's Avatar
Unless you start your car up and immediately go WOT I'm pretty sure this would never happen. Your exhuast gets hot QUICK and again I dont understand why people have this notion that our motors are billowing out massive quantities of oil.. Get some baffles on your vents and be done with it.
Old Nov 12, 2014 | 05:53 PM
kjm's Avatar
kjm
I had welded some extra fittings on my oil pan and was venting the bottom end with vents. My thought was why have blow by having to come up from the bottom end and reduce oil drainage from top end to bottom end
Old Nov 18, 2014 | 08:22 AM
here is a vid of my pcv can switching closed loop to bypass and back during dyno pull
