S480 WS6 Formula Build
Old Mar 30, 2015 | 07:52 AM
  #41
high impact's Avatar
Mounted the boost controller in my dash. I know there are better boost controllers but the eboost2 works with the budget currently. I will eventually uprage to the leash pulse
Old Mar 30, 2015 | 07:53 AM
  #42
Old Mar 30, 2015 | 07:54 AM
  #43
Sitting in front of Hoosier street cars getting ready for the dyno
Old Mar 30, 2015 | 07:56 AM
  #44
After a plug swap and some load testing she's finally ready for some serious hits on the rollers
Old Mar 30, 2015 | 08:02 AM
  #45
After a day of tuning and fiddling with rerouting the boost controller into every conceivable and imaginable way we finally got the boost to work. The car made 871 on 20 lbs with an extremely conservative tune unlocked and 4.10 gears. It's time to swap gears now. We are seeing 80 percent duty cycle on the injectors so they are hanging in there very well.
Old Mar 30, 2015 | 08:04 AM
  #46
Once we get this boost controller figured out it will hold the boost longer so we can rev it out longer and I believe it will make even more power. We had to get out of it early because of this cantankerous controller.
Old Mar 30, 2015 | 08:10 AM
  #47
Corn fed
Old Mar 30, 2015 | 08:11 AM
  #48
 Michael S. Palmer
Old Mar 30, 2015 | 08:40 AM
  #49
Rise of the Phoenix's Avatar
Great work. Bet you're glad to have it all pretty much worked out.
Old Mar 30, 2015 | 08:53 PM
  #50
It enjoyable being able to drive it and slowly work out a few of the little issues I mentioned. Problem is going to be now adding a roll cage, window net, chute. long wheel studs, fire suit, license, etc...to be able to go back to the track. I have a 2 step to install yet also
Old Mar 30, 2015 | 09:14 PM
  #51
Rawr256's Avatar
I'm battling issues with my Eboost 2 also. I need to just go throw the car on my buddy's dyno and tinker with it a bit. I turn it up and boost holds until 5k or so rpm then shoots up. If you figure it out feel free to share any tips!
Old Mar 30, 2015 | 09:36 PM
  #52
1bdbrd's Avatar
Which treadstone did you end up using? I have looked through their site but never can quite figure out which is the right unit for an fbody. Also, aside from the brackets in those pictures, did you have to do anything to the frame rails to mount it or was it cut, bend and drill those 2 small plates and it bolted right up?
Old Mar 30, 2015 | 09:43 PM
  #53
Its the 4.5 inch treadstone 3 inch inlet/outlet, I am not 100 percent which one if there are options other than those. I fabricated those brackets from scratch. I raised the intercooler into place on a bucket with boards and then measured and remeasured then went to town fabricating. I welded fabricated metal plates to angle to make them and position it right where I wanted it...its located just under my bumper fascia where the three tabs mount
Old Mar 30, 2015 | 10:42 PM
  #54
IronBlocked's Avatar
wow look at it go
Old Mar 31, 2015 | 04:10 AM
  #55
SteenH's Avatar
Love the build! beautiful car.
This kind of thing gets me really antsy to get mine done.
Old Mar 31, 2015 | 08:27 AM
  #56
35thsscamaro02's Avatar
What AR is that s480? Looking good!
Old Apr 1, 2015 | 12:21 PM
  #57
Camaro9969's Avatar
Great numbers man especially unlocked and 4.10s bet you can't wait to hit the track!!
Old Apr 1, 2015 | 04:23 PM
  #58
jleews6's Avatar
Nice build! I would think that pulling it to 6800 would show close to 950HP.
Old Apr 1, 2015 | 10:41 PM
  #59
Kmspeedie's Avatar
that 12# pull sounded mean as ****... what exhaust u have on ur car? i love the deep rumble that immediately moved to turbo spool.. i gotta s480 as well and have a quiet exhaust but want somethin mean like yours. love the build glad to finally see it running, gives me hope as im a couple weeks away from drivin mine
Old Apr 2, 2015 | 06:36 PM
  #60
I have a 4" downpipe, bumper exit with a 4" bullet muffler. The turbo is a T4 S480 billet 92/1.10 AR and has a lot left in it yet. We changed the gears to 3.42 so it's loading better now and the tires are sticking a little better.
