brute speed ls2 water pump
Old Jan 13, 2015 | 02:06 PM
dwayneogles's Avatar
Default brute speed ls2 water pump
does it come with a stock (180 degree) thermostat when ordered with the aster bracket or is it a 160??
Old Jan 13, 2015 | 02:23 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
They are supplied with the stock 180 thermostat. Thanks. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jan 13, 2015 | 04:12 PM
Thanks bob we are having to swap for 160 degree and upgrade to spal fans due to overheating
Old Jan 13, 2015 | 04:28 PM
LS1Tech Sponsor
You're welcome. You shouldn't have any over heating problems during the Winter months. Make sure the fans are blowing the correct way, they should be sucking air through the radiator. It's easy to wire them up wrong. Bob
__________________
Old Jan 13, 2015 | 07:30 PM
Dynospeed's Avatar
If your running hot with a 180 stat going to a 160 isn't going to help you. Something else is wrong. When did the overheating start? Does it run hot sitting still, driving, or under boost?
Old Jan 14, 2015 | 10:52 AM
I haven't gotten the car back yet so I'm not sure in the specifics they did the charger install I did the motor build they just notified me of the problem..
Old Jan 14, 2015 | 10:53 AM
LS1Tech Sponsor
I'd confirm with them on the fan rotation, as they are pullers and can easily be wired backwards to blow air into the radiator. Bob
__________________
Old Jan 15, 2015 | 05:57 AM
Problem resolved... Fans were blowing backwards thanks for the input guys!!
Old Jan 15, 2015 | 06:02 AM
LS1Tech Sponsor
Good deal! Bob
__________________
