1999 PCM/FMU question
A friend came across an old procharger kit for a 98 c5 corvette. (he thinks it’s a procharger kit anyway) Considering installing it on a 1999 C5. The kit comes with an FMU for fuel enrichment though. I’ve used FMU’s in the past with great success on VERY mild boosted setups. (4-6 psi). But I’ve never seen them used on an LS platform. Looking online I see no kits that came with any sort of FMU for a corvette. So I’m guessing this may not be part of any original kit.
I know HP tuners or some sort of aftermarket ECU would be best. What I’m wanting to know is if an FMU can be made to work with a 99 LS PCM. And If so, what must be done.
Thank you!
Thank you!
As soon as you hit any boost it will ped out the stock map sensor, that isnt a big deal. On low boost you will not max out the maf but it would cause issues with the maf/map table if you dont adjust the tune. If you max out the maf table it will go into reduced power in a C5.
There is no way around getting the pcm tuned if your wanted to add any kind of boost or to a c5. If you going to to do any mods past basic bolt ons it will have to be tuned.
