E85 will it gum up injectors?
I just mix 3 gallons of e85 to every 2 gallons of premium to give you the 50% e
Mixing half premium and half e85 gets you in the 40% blend area. I plan to try this, this year
All I know is it knocks the bsfc down quite a ways and let's your injectors go much farther than they would on e85
Here is the Delhi study gmctrk is taking about. And from what I have seen... I believe it I be the truth
http://www.nav200.delphi.com/pdf/tec...10-01-0619.pdf
i wonder why some of you guys get the black **** in your system, not the first time ive heard it. maybe regional issues? ??
I wonder if it is certain brand gas stations that people are having issues with? (ie Sunoco, Mobil etc....) Maybe some people can post up the brand fuel they are getting and we can make a "good fuel vs. bad fuel" list?
I'm not sure where you got this information but that is not true at all.
Ethanol is about as clean as a fuel as you can get. Hell people drink the stuff all the time
I've ran 100% Methanol and 100% Ethanol and Methanol is more corrosive than Ethanol. I've also never had a problem with goo of any kind in any part of the fuel system. You just can't leave it in the fuel system if the car isn't going to driven for days at a time. We always ran gasoline through the system until it made it's way all the way through. You could hear the idle change when it was all flushed out.
Anything aluminum that comes in contact with the fuel needs to be anodized and run alcohol resistant fuel lines. Yes, it does mean more work to run it but over the years materials have gotten much better so running it is getting easier all the time. If it were such a problem you wouldn't see so many major car manufacturers producing cars to run it and still offer a warranty.
I think a lot of the problems are due to people running it with parts that just aren't compatible with high alcohol content fuels.
Yes you could anodize the aluminum used to make it compatible with E-blends but unless you buy it as such most people will not go the extra step to do so especially if it was an OEM part installed from the dealer say 10 years ago. I am not sure if the polymer/materials have changed much but noted some issues 4-5 years ago with people using generic off the shelf SS lines. As of recently I have not heard of many issues but to play it safe I had my previous setup with PTFE coated lines to make sure I would have no issues. It was probably overkill and surely much more expensive then generic SS lines but I wasnt taking a chance on that build. This JY build I may be willing to try the off the shelf generic SS and hope for the best.
The gasoline added added is the same gasoline sold at the pumps so I'm not sure where the particulates would come from.
