converting Lq4 block for priority oiling?
Old Feb 9, 2015 | 07:57 AM
rotary1307cc's Avatar
Exactly my point, look at the bearings lol
Go look at that copo build. Good block with stiff crank, and blower...... It looks seriously like new inside. And he can keep it together at weight and as fast
Old Feb 9, 2015 | 08:13 AM
TT427's Avatar
Originally Posted by dmaxvaz
since no one in this thread has converted their blocks to priority oiling, and it's turned into a pissing match, this thread has become useless....
Googled it about 5 different ways, if its a problem then nobody is talking about it at stock block power levels....
Old Feb 10, 2015 | 12:43 AM
Blown06's Avatar
8 Second Truck Club
You need to learn a few things bud. The bearings look the way they do because the crankshaft has a major flexing issue. It has absolutely nothing to do with oiling. You need to stop typing **** that you read about but know nothing about.
You'd be hard pressed to find a single engine builder thats worth a **** tell you those bearings look the way they due because of an oiling problem. My **** makes 95 lbs of oil pressure for a reason.
Old Feb 10, 2015 | 12:46 AM
Blown06's Avatar
8 Second Truck Club
You even point out in this post that this other motor looks good because it has a nice crankshaft in it. If you where trying to argue about oiling issues, this post you made was a big whiff. Proof again that you just regurgitate **** you read about.
You also make a comment about him being able to keep it together "as weight and as fast". Mine was torn down due to a head gasket issue, not a bottom end issue. What does that have to do with our discussion?
Old Feb 10, 2015 | 01:00 AM
Blown06's Avatar
8 Second Truck Club
I can't believe this is a discussion. I'll apologize right now for typing like a dick head. Just to be clear though...........you're saying that the bearings out of my motor (in the pics above) look the way they due because of an oiling issue, right? You can answer yes or no
I just wanna make sure we are on the same page and not arguing back and forth over two different subjects.
Old Feb 10, 2015 | 07:56 AM
No I'm not saying it is from oiling. But can you say for certain a priority block wouldn't help?
Go look at that copo seriously. Its like new
Old Feb 10, 2015 | 07:57 AM
I say it because you make it sound like a priority block is a joke. Where if you actually looked at a stock block compared to one with priority you would see the stock is a joke IMO
Old Feb 10, 2015 | 10:54 AM
SHAWN@PRACETECH's Avatar
those bearings look the way they do from crank flex, and maybe too little clearance. you can expect to see this a lot in non center counterweight crankshaft applications that see a lot of power and rpm. I can't see the faces of the main caps very well but more than likely they are fretting a little without dowels. This is certainly not an oiling issue. I can say with a high level of certainty that a priority main block would make no difference other than they usually have dowelled mains which might help some.
Old Feb 10, 2015 | 10:59 AM
Originally Posted by slowride
Shawn, do you think restricted pushrods help much for the leakage or not?
not really unless you have an oil drainback problem
personally I have not seen anybody covert a block to priority main oiling. I'm not even sure it's possible and if it is it would not be cost effective and probably too complex to work properly. I was trying to give alternative solutions to this based off of what I have seen work in the past. we've made 1800 hp on a stock ls2 block with zero oiling issues. it's not needed if the engine is built correctly.
Old Feb 10, 2015 | 01:05 PM
Lol learn a few things lolz
Old Feb 11, 2015 | 12:09 AM
Blown06's Avatar
8 Second Truck Club
So if "it is not from oiling", what would the oiling strategy (priority mains) have to do with it. Yes, I can say for certain a priority block would not help my crank flexing issues.
This argument is pretty much done now.
Old Feb 11, 2015 | 08:52 AM
  #32
Yes u have it all figured out it seems
Old Feb 12, 2015 | 02:50 AM
  #33
Blown06's Avatar
8 Second Truck Club
lol, there was nothing to "figure out".
Nobody is disagreeing with you saying that priority oiling isn't better. It is. The point was that there never seems to be any issue with the ls that changing the oil strategy would fix. Given the cost and trouble, if it could even be done, it just doesn't make sense. Now, the pump on the other hand does have issues, but that a different topic.
I pursued this thread after you bashed my bottom end, then gave an incorrect reason why is looked the way it does. Just setting the record straight.......especially when it involves something of mine.
