Compression on E85?
Old Feb 6, 2015 | 02:38 PM
Meth Sled's Avatar
Originally Posted by gnx7
11:1 compression 378ci forged motor on e85 running a stock $100 ls1 crank making over 1000rwhp for a few thousand hard miles. No issues. Spools a T4 88mm turbo with minimal lag. In out area it varies from 78-85% depending upon station and time of year. I have an ethanol content meter to always let me know what I'm running. Typically you find a good station and they will consistently have high levels. Midwest in the winter the content goes down more then west coast as colder weather makes it harder to start an engine on a purer blend.
Just a little over $2/gal for 106 octane fuel is the best! If you buy a quality injector that can operate well at low DC then tuning is easier and idle/low end response is good until you really need the DC at higher boost levels.
I plan on running DeatschWerks 1500cc injectors, yay or nay?
Old Feb 6, 2015 | 02:59 PM
gtistile's Avatar
I'm new to E85 as well, but my experiences have been spot on with what other guys have mentioned. The car was tuned with 83-84% Ethanol and the tuner left enough of a window to let it run well as low as 70% or so. The summer blend here is 86% consistently and the winter blend is 74-75% at its lowest. I bought a $15 E85 tester off of Summit and test the fuel every few fill-ups and have never had any tanks' content surprise me. Tune hasn't been altered and it has run great with anywhere from 74-86%. My application is a little different being a 10:1 LS7 and an overspun 2.9 Whipple, but I feel it speaks well to knock resistance of the corn fuel. I can generate A LOT of cylinder pressure at very low rpm and have no issues at all. If you have good access to E85, go for it!
Old Feb 6, 2015 | 03:47 PM
Meth Sled's Avatar
Does E85 expire? If I were to have a barrel and keep at the house or take to the track or an event.
Old Feb 6, 2015 | 04:50 PM
gnx7's Avatar
It is hydroscopic meaning if not sealed tightly it will absorb moisture. I'd say tightly capped it should be fine for a few months.
Ansu or ID are the best. If you are super picky about driveability. If you just care about wot performance throw a dart and pick one.
Old Feb 6, 2015 | 04:56 PM
Meth Sled's Avatar
Then price difference isn't nearly as bad for the 1500's as I assumed. I'll run ID's most likely.
Old Feb 7, 2015 | 08:44 AM
willizm's Avatar
FWIW I store e85 in a 55 gallon polyurethane blue barrel and have absolutely no issues doing this over winter and into the following summer. Now i'm sure the ethanol police are going to light me up for not using a full stainless steel drum and only storing it for 3.75 days before it becomes useless and have to properly dispose of it, but that is what I do with a good deal of success. In October/November (when it's still 85+% ethanol) I fill the drum up and seal it tight. When spring comes along or during winter tuning days I use it without an issue. I've stored it up to 6-8 months at a time with no problem. Been doing this for 3 years now
#EthanolPoliceWon'tLikeThis #FlameSuiteOn #BlahBlahBlahImproperBlahBlahBlah2DaysMax
Old Feb 7, 2015 | 09:20 AM
Forcefed86's Avatar
I store it too. FWIW though this doesn't mean its not absorbing moisture. It's not like you can read the amount of water it has absorbed and test the actual octane levels with our little test tube percentage rigs. Unless you pull all the air out of the drum with a vacuum, every time the temperature changes rapidly moisture will form on the inside of the barrel (condensation) and this will be absorbed into the fuel. Yes, it helps to have the drum sealed, also helps if it's stored at a constant temperature. Depending on humidity levels and storage techniques the fuel will degrade over time. Weather it degrades enough to actually affect your engines performance is another story.
Old Feb 10, 2015 | 06:48 PM
LLLosingit's Avatar
Since nobody mentioned it I will. How well your engine will tolerate the change from E85 to something lower say E65 has just as much to do with boost as it does your tune.
If you tune for E85 at 25lbs of boost and you find yourself with no choice but to run E65 you can turn down the boost and still not worry about killing your engine. Unlike what some seem to think you will be running richer as the alcohol content drops but at the same time your chances of detonation rise. Keep the boost down until you get the fuel you are tuned for.
Also keep in mind that if you tune for E65 and run E85-E90 you will be running lean and the risk is higher that you will do permanent damage but you can always bring the alcohol content down by adding more gasoline.
Old Feb 10, 2015 | 08:25 PM
Meth Sled's Avatar
I'm gonna hunt around to find the best E85 and tune on it, then test each fill-up and adjust accordingly.
Old Feb 21, 2015 | 08:55 PM
S2VYSS's Avatar
Does the amount of compression change if the bottom end is still stock??
Old Feb 21, 2015 | 09:16 PM
GMCtrk's Avatar
That's not necessarily true. There are several scientific articles out there showing that E50 has as good knock suppression as E85. My personal use supports that as well.
Old Feb 21, 2015 | 09:38 PM
  #32
Meth Sled's Avatar
The only way to alter compression while leaving the bottom end alone is using thinner or thicker head gaskets, altering block deck height, or milling your heads or swapping to a set with a lager or smaller combustion chamber. Depending on what direction you want your compression to move.
Old Feb 22, 2015 | 09:11 AM
  #33
Razor's Avatar
~10.7 ish' to 1 compression with a Maxed out 2.3 Whipple in my car.
Pump E85 and 95lb injectors in 110° F+ heat.
No issues. I would not go any higher than 10.5 to 1 compression for my next build. As mentioned previously in this thread, the tuning window becomes smaller and you can make more power with less compression and more boost vs. more compression less boost.
Also, I would keep the 4x4 in that truck. Should be fun.
Old Feb 22, 2015 | 11:43 AM
  #34
samdogmx's Avatar
my last motor was 9.0 new one is 10.1 like has been stated already every combo will be different and there is no "best" answer.
but more compression will always mean more power.
Old Feb 23, 2015 | 06:49 AM
  #35
S2VYSS's Avatar
Thanks for the answer, I should have been more clear with the question as it was confusing and made no sense after I red it again. If you milled the heads down but stuck with a stock bottom end is there a limit to where the combination of stock bottom end, compression & boost over come the benefits of E85?? Or is it a how long is a piece of string question??
