ls1 turbo 383 build
Old Feb 20, 2015 | 11:14 PM
boosted383's Avatar
Default ls1 turbo 383 build
Its finally time to to start my first build on my 02 z28. Iv helped my cousin with his but now its my turn.
My plans are to have an 800+ whp street/track car. Mostly track but would like to take it out on the weekends to car shows.
I havnt started ordering parts yet but im going to put a list up of what I plan on getting.
ENGINE
LQ4 block
Eagele rotating assembly 3.905" bore
- 4340 4.000" crank
- 6.125" hbeam rods
- mahle forged pistons -26cc
- AFR LS1 230cc fully CNC ported, 65cc chambers, complete w/parts
- 9.06:1 CR
- dmp engine girdle
- arp bolts and studs threw out
- cometic gaskets threw out
POWER ADDER
Huron t4 twin turbo kit
- pair of pt6766 bb
- pair of turbosmart hypergate 45mm wastegates
- pair of turbosmart race port 50mm bov's
- bell 4.5" high efficiency core intercooler
FUEL
- Aeromotive Eliminator Stealth Fuel Cell. With intank eliminator pump
- Aeromotive Extreme Flow EFI Regulator designed for eliminator pump
- Injector Dynamics 1000cc Injectors
- alky control meth injection setup
-HOLLEY LS HI-RAM EFI MANIFOLD
-Holley HP EFI ECU & HARNESS KIT
-Holley BILLET 105MM LS THROTTLE BODY W/STRAIGHT BORE
BMR for suspension throughout the car.
And thats it for now. Any and all Info will be greatly appreciated.
zak
Old Feb 20, 2015 | 11:25 PM
94LS1B4C's Avatar
zak
Is this going in an F car? If so how do you plan on fitting this?
Old Feb 21, 2015 | 09:28 AM
boosted383's Avatar
Yeah 02 z28.. and ill get a 4 or 6 inch cowl hood. And its not a deff that im getting that intake might go with fast lsx-r intake with 102mm tb. Just liked the look of the holley intake and tb and its a good bang for the $.
Old Feb 22, 2015 | 10:15 PM
boosted383's Avatar
Any body willing to help me out with some info?
Old Feb 23, 2015 | 10:46 AM
red_00z28's Avatar
What about going with a super vic/4150 Tb setup, or a pro-flo XT. either way say goodbye to wipers and most of you're cowl. FWIW I have no regrets about cutting my cowl to fit the super victor, well worth it. the AFR 230cc cylinder heads you suggest would work, maybe mill them to get the desired compression ratio. For the cam I would suggest a shelf cam that's designed for a turbo setup or if you wanted a custom cam call Martin@tick, Brian tooley, or any of the excellent LS cam guys out there. Cant go wrong with any of them. Now the transmission, I would suggest a 4l80E. this is just my .02 so take it for what its worth. Good luck, sounds like a sweet build.
Old Feb 26, 2015 | 10:36 PM
boosted383's Avatar
Changing up my fuel system going with:
-Aeromotive Eliminator Stealth Fuel Cell. With intank eliminator pump
-Aeromotive Extreme Flow EFI Regulator designed for eliminator pump
-Injector Dynamics 1000cc Injectors
Does any one know if theres a sequential manual transmission out there to put behind an ls1? Or has anyone evin heard of this being done with an ls1? Been searching up and down the net for one of these for my car or one that would fit the car and have had no luck at all.. Iv seen these transmissions in a corvette on youtube but thas the closest thing iv seen related to gm and these transmissions. Any info would be apreciated
Old Feb 26, 2015 | 10:41 PM
JoeNova's Avatar
Restricted User
The sequentials are extremely expensive. I don't see you gaining anything for that amount of money unless you're doing some serious road racing.
As far as automatics go, its up to you. If you want a 2 speed, powerglide. 3 Speed, TH400, overdrive and lockup, 4L80e.
As far as manuals go, the tried and true T56. You'll need a fairly well built one if you want it to last.
Old Feb 27, 2015 | 01:58 AM
Johnv's Avatar
your turbo choice is on the small side for a 383, I prefer wiesco pistons and your target static compression is on the low side.
I would go with the smaller 95 mm tapered bore Holley for better drivability over the straight bore 105 mm, with boost there will be very little difference in performance between the two.
Old Feb 27, 2015 | 07:37 AM
SwampWS6's Avatar
I personally think that the turbo is also too small. And I would bump up the compression to at least 9:0-9:5. Is there a reason for such low compression? Wouldnt that turbo max out sooner being that the turbine size is smaller and it could only hold a certain max PSI?
Old Feb 27, 2015 | 08:16 AM
Sales@Tick's Avatar
Make sure that you do not use a cam with a lot of valve overlap with the combination you're building. With that turbocharger on that size engine, it will be very easy to "overrun" the turbocharger.
In simpler terms, the engine wants more airflow than the turbo can give. Causing back pressure issues and power loss.
Old Feb 27, 2015 | 08:00 PM
boosted383's Avatar
Going with afr 230cc heads with 65cc combustion complete with parts. With them heads ill have 9.06:1 cr. Going twin turbo instead of single with turbonetics t7575 turbos. Turbos still to small? I changed the build a lil bit to. this is going to be a track only car now. Dont feel like going threw all the bull to keep it on the street.
Old Feb 27, 2015 | 08:11 PM
s57_s2k's Avatar
I suggest that you check cylinder wall thickness (sonic testing), at your power level the walls will deform if there is not enough material.
Good luck
Old Feb 27, 2015 | 08:33 PM
JoeNova's Avatar
Restricted User
Those are some pretty damn big turbos for twins haha. Thats about 1800 HP worth of turbos.
Old Feb 27, 2015 | 08:37 PM
boosted383's Avatar
Also adding in dmp engine girdle
Old Feb 27, 2015 | 08:50 PM
boosted383's Avatar
Good luck
yeah alot of people say that. But I read about people pushing 1000+whp with ls1 block with out the walls deforming cracking or anything bad happening. I know the risk is there but ay life would be boring with out taking risks. Lol. And if the block doesnt hold up ill get an iron block and start another project.
Old Feb 27, 2015 | 08:54 PM
IronBlocked's Avatar
Now that's a man talking, best of luck with the ole LS1, although the 3.905 bore scares me a little.
Old Feb 28, 2015 | 12:24 AM
rkreigh's Avatar
nice build, if the ls1 block scares you, I have a fresh 4.8 build
nice selection of parts
interested in the dmp girdle
thanks for posting
I think that 1800 might be a good start
Old Feb 28, 2015 | 09:40 AM
boosted383's Avatar
Im thinking injectors might be a lil small.. anybody think the same way? Does any one kno if aeromotive ls1 fuel rails will bolt up with the holley high ram intake? Jw cuz Im trying to go with a red and black theme. I kno the intake comes with fuel rails but instead of black I want red.
Old Feb 28, 2015 | 04:26 PM
rkreigh's Avatar
I ran the fic 127s with a whiff of drugs (meth) to be safe
I'm thinking of going with a stronger direct port meth setup and welcome the dependency
the haltech has some nice safeguards if there are issues to cut spark or dump boost
Old Mar 1, 2015 | 03:56 PM
boosted383's Avatar
not sure if I want to take a whiff of drugs. Mommy told me not to give in to peer pressure and be a leader not a follower lol. Daddy would beat my *** lol.
Heard some things about burning out piston rings and things of that sort. What are some pros and cons of meth
