Help 5.3 Turbo
Old Feb 23, 2015 | 05:17 PM
onesloGTO's Avatar
Default Help 5.3 Turbo
Needing to know what spark plugs to use. Currently has ngk tr9. A tuner I talked to recommended tr6. So I have no idea.
Also, What gap?
Thanks
Old Feb 23, 2015 | 05:33 PM
JoeNova's Avatar
Restricted User
Most use the TR6 or the BR7EF. I use the 7s. The debate could go on for hours between the two.
Old Feb 23, 2015 | 05:55 PM
onesloGTO's Avatar
So definitely not a tr9?
Old Feb 23, 2015 | 06:24 PM
JoeNova's Avatar
Restricted User
The nitrous guys usually run the 9s. Anything colder than the 8s and I've had pretty bad idle quality from them. When you have a big cam nitrous setup, you don't care about idle.
Old Feb 23, 2015 | 06:46 PM
onesloGTO's Avatar
See I've used tr6 with nitrous in the past.
Old Feb 23, 2015 | 08:25 PM
JustAFooL's Avatar
BR7EF here
Old Feb 23, 2015 | 09:14 PM
ForceFed66's Avatar
These are the ones I'm running..
NGK Part Number: B8EFS
Old Feb 24, 2015 | 07:20 AM
LS1NOVA's Avatar
Br7ef
Old Feb 24, 2015 | 07:50 AM
onesloGTO's Avatar
What gap?
Old Feb 24, 2015 | 09:19 AM
JustAFooL's Avatar
I just ran mine out of the box.. I think that's what a lot of people do
Old Feb 24, 2015 | 11:46 AM
JoeNova's Avatar
Restricted User
They seem to be good out of the box to a little over 15 PSI in most setups.
Old Feb 24, 2015 | 12:36 PM
cptinjak's Avatar
No one can answer this question without knowing your power level and a little about the setup...
Jack
Old Feb 24, 2015 | 01:10 PM
Forcefed86's Avatar
Start cold, give it what it wants. 100+ threads will pop up on this subject with a quick search.
Old Feb 24, 2015 | 02:26 PM
onesloGTO's Avatar
04 5.3 stock bottom end
243 heads stock
arp studs
ls9 head gaskets
comp cams dual springs
custom grind boost cam 114lsa
mpt70 turbo .96 ar
KY turbo kit 3in down pipe
50mm bov
41mm waste gate
80lb injectors
fast fuel rails
ls6 intake smooth and painted
performabuilt 4l60E stage 2
3600 edge converter
sphon front k-member solid motor mounts
sphon torque arm and sway bar
Founders panhard bar
sphon 1.5 drop
stock 10 bolt 3:37 gears from motive
e85 twin granatelli 340 fuel pumps in tank
