What size injectors...
Old May 31, 2004 | 01:40 PM
slyws6's Avatar
Default What size injectors...
For an all forged 8.6:1 370ci LS1 with PP Stage 3 LS6 heads and a T70 with 20lbs of boost??
-Sly
Old May 31, 2004 | 11:28 PM
Caveman's Avatar
10 & 11 Second Club
You would probably need 60lb - 65lb inj, 83lb might be too big.
Old Jun 1, 2004 | 01:05 AM
BIGBOS's Avatar
83's are never too big, but they are low impedance, and that means you need a converter box....
75lbs are the highest high impedance out there right now, I will probably use these if my 60's don't carry me to where I need to be, I'm sure I'll make it though.....
Old Jun 1, 2004 | 01:38 AM
QuickSilver2002's Avatar
I think 60s can get you to 750RWHP. After that, you need to go low imp or pay the big bucks for custom high imp.
Old Jun 1, 2004 | 02:07 AM
NA$TY-TA's Avatar
I ould say Motron 60#ers they are 60#'s at 3 bar or 43.5psi..... way higher at our 4 bar 58 psi system..... im running them same as Bos.
Kyle
Old Jun 1, 2004 | 07:05 AM
slyws6's Avatar
Cool thanx guys I was figuring 60lb'ers was the way I was going to go. Anyone know where to get them the cheapest?
-Sly
Old Jun 1, 2004 | 08:09 AM
BIGBOS's Avatar
Through a GP or if I decide to sell mine if my SD stuff doesn't work
Old Jun 1, 2004 | 08:22 AM
smokinHawk's Avatar
hmm do you think a T70 will support your 20psi?
unless you have some corked exhaust i dont think youll get there.
Rob R was only able to get around 15 psi before he ran out of turbo on his T76
i think the T70 will be able to supprt around 650rwhp, so 55's sould be plenty.
 Michael S. Palmer
Old Jun 1, 2004 | 08:23 AM
BIGBOS's Avatar
On a 370 I would at LEAST do a t-76 with a big housing, if I was going turbo I would for sure stuff an 88 in there though
Old Jun 1, 2004 | 09:55 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Depends which 70 it is. Their is a new 70 out which is making 850rwhp on a TH400 in a GN . If its a 70 p-trim....then no, boost will fall off. A 370 at 6500 rpms will require ~90 lbs/min, at that PR you will be past the choke line on a T70. The turbo will work ok in the lower boost levels.
Map is below
Click here
Jose
