FAST E-dist and Crank Trigger box?
Old Jun 5, 2004 | 07:16 AM
Redline-Motorsports's Avatar
Jack,
I know when I was out a SEMA last fall, the GEN 7 still required an aftermarket crank trigger. They did state they where working on a there software to make the stock LS1 crank sensor work. I assume from your post that it is finally out?? I can't make up my mind for which system to use for our 62' Nova Pro-Touring project. Motor is a big twin turbo setup and we want maximum ability!
I would rather use a system that utilizes the factory sensors so the GEN7 is out in front. What do you guys know about "Big Stuff"??
Old Jun 5, 2004 | 07:27 AM
GTP40's Avatar
The GEN 7 has it's own decoder box that ships with the LS1 system. No need for a crank trigger, the DFI can plug right in and use the existing stock sensors and coils.
Old Jun 5, 2004 | 12:33 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Yah the Gen7 has a crank decoder that comes with it now.
BS3 reportedly is plug'n play, and no connectors need to be redone. I believe that it would be hard to get one of the first 20 BS3 boxes, so maybe check with Kurt @ W2W to check availibility.
Old Jun 6, 2004 | 04:20 PM
LS1Tech Co-Founder
Justin, the standalone conversion has/was/is pretty hard FYI. In the end, the crank box is not hard to put in but the eDIST is time consuming and we had to look at the paperwork a few times before starting on it.
Old Jun 6, 2004 | 09:28 PM
427's Avatar
427
Big Stuff is just now filling back order's.
The system is stand alone with no adapters. Plugs directly into coils, cam sensor, tps, map (need to know 1-2-3 bar when ordering) and stock crank position sensor. It will raise the bar in affordable aftermarket ECU's.
Kurt
Originally Posted by 9D9LS
Jack,
