FAST E-dist and Crank Trigger box?
I think I would reccomend that you PM '427' and ask Kurt from W2W for those parts. He has spent a ton of time with me to help figure out how to wire the car up and I should be done sometime this week.
I will attach some pics of the parts tomorrow.
-You have a FAST bank/bank setup on there now just controlling fueling with the Cartek crank box...
-To run full FAST as a standalone you will need to wire in an eDIST, and a crank solution ie the crank box from FAST or an MSD crank trigger
-Right now you have very little from the FAST wired in, just the map sensor, iat sensor, hybrid crank, and coolant temp sensor, if your setup is like how mine was
-To go standalone you need to wire in as well, the iac, tps, cam sensor, rewire the crank sensor, come up with a solution for your dash gauges, and other stuff like the starter and alternator
-If you could have a shop do it, it might be worth it, it's up to you
P/N 77050 apx. street price is $2150.00US.
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
I will touch base with F.A.S.T. in the next couple days to ask how far they have come on the LS1 firmware & sensor compatibility. Last I spoke with them was at the PRI show in Dec and there was nothing available then.
Jack
Racetronix
>WEB SITE<
Try Kurt @ W2W at kuperf@aol.com or try other vendors. But Kurt is the one that really knows how to wire it all up and he's the one you will want to PM, IM , or call with questions.
The eDIST runs the coils, and the crank decoder converts the LS1 24x signal to a 4x.
How do they get the cam sync out of that box for SEFI operation?
>WEB SITE<
The crank box is not available to the public yet, that will be your main problem.
The e-dist is a easy purchase. It takes some wiring skills to install but we can walk you thru it.
Thursday later in the day I should be done putting out fires if you want to call.
Kurt
586-757-1961
What kind of dampner do you have Justin?
Rob Ill try to get ahold of u if i can may drive there this weekend and pick up the crank box and have u look at the car. Its just a lot easier since ur pretty local to me.
The release of the production decoder box i'm told will be soon.
Kurt
