HP Guesstimate !!
Old Mar 15, 2015 | 09:22 AM
BUDGETRAT's Avatar
Default HP Guesstimate !!
First turbo build so what's your guys guess on what it will make getting it tune April 4. Here's what it is. 09 Ly6(6.0) w/ stock L92heads, BTR springs , one of Stock 48s cams (218int. 228 exh. ),S475 T4 w/92mm 1.10 AR on KB racing style log, truck intake and 120 Holley injectors , through a glide with PTC converter if need more specs let me know. I hope I'm not disappointed went from a BBC running 9.70s to this.
Old Mar 15, 2015 | 09:36 AM
LS1NOVA's Avatar
Old Mar 15, 2015 | 10:06 AM
Razor's Avatar
I see the 120's..guessing E85?
Thing should rip.
Old Mar 15, 2015 | 10:10 AM
BUDGETRAT's Avatar
Yes E85 magna fuel 4303 pump
Old Mar 15, 2015 | 12:41 PM
JoeNova's Avatar
Restricted User
Did he spec the cam for you? That seems like fairly big duration split for a 6.0 with a single T4.
Should make 800 as said before. E85 will help a lot.
Old Mar 15, 2015 | 02:25 PM
BUDGETRAT's Avatar
Yes he specd cam I think the L92s had something to do with it
Old Mar 15, 2015 | 02:28 PM
BUDGETRAT's Avatar
Sorry fat fingered it lol. It's 218/224
Old Apr 3, 2015 | 09:55 PM
BUDGETRAT's Avatar
Well wish me luck will hopefully find out tomorrow what it does then hope to get it to track in a few weeks
Old Apr 4, 2015 | 10:00 AM
tblentrprz's Avatar
If theory holds true, injector at 43 good to 1100fwp, at 60 1300fwp
turbo w/ billet wheel and race cover should give you ~30# and above hp numbers.
Let us know how much you turn it up.
Old Jul 8, 2015 | 06:49 AM
BUDGETRAT's Avatar
Sorry it's been awhile here's a video of second pass on combo https://m.youtube.com/watch?v=F6CYWPyhbg4. Threw a belt on that pass so no more that day. That was on 14lbs of boost and shifted way early into second gear.
Old Jul 8, 2015 | 06:51 AM
BUDGETRAT's Avatar
Old Jul 8, 2015 | 07:56 PM
ls3fox's Avatar
7 Second Club
Cant see what it ran and how much did this thing lay down?
Old Jul 8, 2015 | 08:34 PM
BUDGETRAT's Avatar
Dyno showed 640 rwhp but was told it was very stingy since he does a lot of X275 cars. That was on 12lbs of boost. Run was on 14 so far
Old Jul 8, 2015 | 08:38 PM
BUDGETRAT's Avatar
Old Jul 10, 2015 | 06:44 AM
forcd ind's Avatar
Pretty cool, good 60' times
Almost the same setup I have in my Buick, except I have the 317 heads
I hope to get around 500 to the rear wheels, depending on where the boost ends up, more wouldn't hurt my feelings, lol
Old Jul 10, 2015 | 01:44 PM
IronBlocked's Avatar
Damn you picked half a second, and that's on a tiny hyd roller from your big block
