How much timing initially....
Old Jun 1, 2004 | 05:25 PM
slyws6's Avatar
Default How much timing initially....
The setup once again...
Forged 370 (8.6:1), PP Stage 3 LS6 heads, T70
How much timing should I start off with running the following amount of boost:
6lb's - ??
10lb's - ??
15lb's - ??
20lb's - ??
I've never tuned a FI car and heard you run much less timing than N/A. I started a base tune even tho the engine isn't in the car yet. I took the factory table I had (well I had adjusted max timing to 30 degrees) and multiplied it by .6 and that gave me total timing at 19 degrees. I modified the low octane table by .7 but don't remember the total timing off of the top of my head. Now does the rest of the timing table matter, should I keep it at stock or modify it? Right now it's 60% lower than factory. Opinions please....
-Sly
Old Jun 1, 2004 | 05:44 PM
MIGHTYMOUSE's Avatar
i am thinking you are using a stock computer and ls1 edit for this by your high and low timing table comments.. that being the case how are you going to input any information vs boost?? there is no boost table.
at any rate with the compression so low i would start off with a completely stock timing table, copy it to the low table so they are both the same.. then i would pull it down to about 24* in the load ranges larger than .6 between 3000 and redline.. start off with maybe 6# of boost. you will have to work your timing table as you go up in boost off of the last load range.. you also need to mention the octane you are going to be running.
Old Jun 1, 2004 | 05:50 PM
slyws6's Avatar
I'm using the stock computer with HP Tuners. What else can I use to tune for boost? I'll be running on 93 octane and using a meth injection kit with the higher boost levels.
-Sly
Old Jun 1, 2004 | 05:53 PM
slyws6's Avatar
Please excuse my ignorance, I'm new to the FI world. I blew stock bottom end and having a shortblock built for boost. I plan to run the boost really low while learning more about it and prepping for higher boost.
-Sly
