Guidence Request - New to LS and Boost
Old Mar 29, 2015 | 05:20 AM
2KGRM9's Avatar
Default Guidence Request - New to LS and Boost
I am new to LS and Boost.
Is there a thread or information link/source for a beginner to build a boosted LS? Specifically, I am looking for a step by step guide.
I am also interested in buying the right parts new or second hand. Ideally, I want to use the original computer and an external fuel pump.
What I have is a '03 5.3, manifolds, harness and computer from a Suburban. I also have (2) small turbos and (1) large turbo.
Thanks in advance.
Old Mar 29, 2015 | 10:19 AM
Black89Z51's Avatar
Thanks in advance.
Pretty sure that's a fly by wire throttole body. If so, you're probably going to want the accelerator pedal and the tach box associated with it.
Old Mar 29, 2015 | 11:08 AM
2KGRM9's Avatar
I have to back to the salvage yard to get the pedal.
What is the tach box?
Sorry, I am that new to LS.
Old Mar 29, 2015 | 06:56 PM
1bdbrd's Avatar
What chassis is this going into and what size are your turbos?
Old Mar 29, 2015 | 07:39 PM
Black89Z51's Avatar
It's an electronic box bolted to the firewall between the brake booster and the driver's fender. One of the wires runs through the firewall to the accelerator pedal. Just push the wire into the cabin and remove the pedal.
Old Mar 29, 2015 | 08:16 PM
2KGRM9's Avatar
I will chase that down next weekend.
Old Mar 30, 2015 | 04:44 PM
a.white86's Avatar
There's a pinned post at the top of the Forced Induction section to answer a lot of what you're probably going to ask.
Old May 3, 2015 | 05:08 AM
2KGRM9's Avatar
Is there a way to glue pieces into the holes that are in the intake? Or is there a good way to plug/cap them?
Old May 5, 2015 | 07:32 AM
rkreigh's Avatar
not secure enough for boost
you can drill and tap and plug it but the composite nylon stuff doesn't glue all that well that I know of
back to the original post, hang out here and you'll learn all you need to know.
and keep asking questions! there are no dumb questions, and verify the answers you get.
there is wisdom in many council.
Old May 5, 2015 | 07:35 AM
2KGRM9's Avatar
Thank you.
Old May 23, 2015 | 05:35 AM
2KGRM9's Avatar
We are changing the throttle body and computer to a '01 unit.
Any good direction/posts/links for a DIY Methanol Injection System?
Old May 23, 2015 | 05:43 AM
2KGRM9's Avatar
Can the factory fuel regulator be used for boosted application?
Old May 24, 2015 | 10:33 AM
asubennett's Avatar
Denmah has a boosted ls1 info wiki created. Google it.
Old May 30, 2015 | 05:09 AM
2KGRM9's Avatar
I did not have any luck finding it. I am not goot a searching and often rely on my somn to find stuff on the net. Can you direct me to the information?
Old May 30, 2015 | 06:57 AM
Five O's Avatar
https://sites.google.com/site/sloppywiki/
I think this is what your looking for
Old Jun 3, 2015 | 04:47 AM
2KGRM9's Avatar
Thanks. Lots of great info.
I am in York, PA. I would love to meet the person/folks who are doing this work.
Old Jun 17, 2015 | 05:44 AM
2KGRM9's Avatar
What is a good redline for a boosted stock 5.3? I've read 5800. I'd like to go 6200. Any advise?
Old Jun 17, 2015 | 07:46 AM
JoeNova's Avatar
Restricted User
Where ever it stops making power...
6200 is fine. Some go even higher.
Old Jun 21, 2015 | 08:13 PM
2KGRM9's Avatar
Default Max redline for a boosted 5.3?
Higher?
It's a 2001. WHat is the redline with 12+ pounds of boost?
