LSA Crankshaft
Old Apr 27, 2015 | 09:00 AM
  #41
oscs's Avatar
Here is a good example. These cranks are 4340 forged pieces. These see hundreds of thousands of pounds of load day in and day out. These crankshafts go inside of hydraulic fracturing pumps were the amount of pressures and loads are hard to even comprehend. As you can see they are full radius cuts.
As stated previously an undercut radius is a fast/cheap way to relieve the stress at the corners of the throws but is by no means stronger.
Old Apr 27, 2015 | 09:35 AM
  #42
rotary1307cc's Avatar
Stevie is ttalking of a splined app too
Different for sure
Old Feb 12, 2023 | 11:36 AM
  #43
poltergeist 02's Avatar
Originally Posted by rotary1307cc
Also keep in mind that LSA has an undercut radius just like a stock cast crank. Not like an aftermarket
Pic. Stock and lunati pro.
Attachment 660626
Same. Stock and lunati pro
Attachment 660627
I know this is an older post but I was wondering if the double crank sprocket in this picture is a one piece design? If it is, do you know what brand it is?
