List your fuel system setup
Old Apr 27, 2015 | 08:25 PM
94LS1B4C's Avatar
Default List your fuel system setup
I'm curious to here what kind of fuel system setups the turbo guys are running.
Old Apr 27, 2015 | 09:09 PM
Shownomercy's Avatar
Man-Crush Warning
sumped tank, magnafuel 625, stock fuel lines/filter, remote mount aeromotive reg, 6an lines to rails, 80# sticks.
Old Apr 27, 2015 | 09:14 PM
sabastian458's Avatar
Dual 340 aeromotives, y-block into -12 bulk head, -12 line to engine bay, t-fitting in to -8 rail fittings, into regulator, into stock feed line back to the tank. Will be running this on a C5
Old Apr 27, 2015 | 09:26 PM
HeavyMetl's Avatar
Sumped fuel cell, -10an feed, -8an return, Holley 12-1800 pump, Holley 1:1 regulator. Precision 65lb injectors. 100 micron and 40 micron steel mesh filters pre and post pump. E85.
May be overkill, but by God I dont have any fuel delivery issues other than injector limits!
Old Apr 27, 2015 | 09:29 PM
Fat Jesus 808's Avatar
80lb injectors and a walbro 450
Old Apr 27, 2015 | 09:44 PM
SPRAYED 01's Avatar
Dual walbro 255 intank, hobbs switch to turn on 2nd pump at 4psi. Stock feed, stock evap line as return, speed inc rails, aeromotovie 1:1 regulator, 80lbs injectors. Alky control 100% meth, dual 15 nozzles.
Old Apr 27, 2015 | 09:51 PM
Kmspeedie's Avatar
squash dual 450 walbro's (MOST badass drop in piece available and will support all i can ever need),hobbs switch, 8an feed and stock feed used as return, magnafuel regulator&fuel filter, edelbrock rails with siemen 80# deka's.
Old Apr 28, 2015 | 10:43 AM
mkvamso's Avatar
Racetronic dba 510 pumps, -6feed and return, hobbs switch, aeromotive referenced regulator, 84lb injectors on e85
Base pressure is set to 70 to try and squeeze a little more out of the smallish injectors
Old Apr 28, 2015 | 10:58 AM
93camaro_zzz's Avatar
Triple Walbro 255's, -8 feed, Magnafuel FPR, Edelbrock Rails, 80# Siemens injectors, on e50.
Old Apr 28, 2015 | 11:16 AM
vettewreck's Avatar
Dual Walbro 450s, Magnafuel regulator, Racetronix 160lb injectors, Holley fuel rails, E85
Old Apr 28, 2015 | 11:34 AM
Only ERO's's Avatar
Stock tank
-10AN Feed Split to -8AN to each Fuel Rail
-8AN return
Dual Walbro 450’s plus Walbro 255 intank
2nd and 3rd pumps triggered through Holley Dominator
Holley Fuel Rails
Fore Innovations Regulator and Fuel Filter
Holley 160lb low impedance Injectors
Old Apr 28, 2015 | 11:50 AM
Orr89rocz's Avatar
Stock plastic 99-02 tank
Triple walbro gss340m's 255 lph
Fuel lab filter
-8 feed -6 return
Fuel lab regulator
Fic 127 lb injectors but at 40 psi base
Dual pumps supported 1009 whp so far. Triples not tested yet
Old Apr 28, 2015 | 01:31 PM
jmm98LS1's Avatar
stock 98 tank
dual walbro 450s, 2nd pump on 2psi hobbs switch
fuelab 6 micr filter
-8 feed, split to -8 to each rail
edelbrock rails
FIC 160LB injectors
magnafuel referenced FPR, 43psi base
-6 return to sending unit into factory 3/8" feed line
E85
Old Apr 28, 2015 | 01:49 PM
94LS1B4C's Avatar
I see a lot of you guys running magnafuel regulators. What is the part number you guys are using? I thought the popular one was Aeromotive. Also, what are you guys running for wiring?
Old Apr 28, 2015 | 02:18 PM
meatheadgn's Avatar
Magnafuel 4303 pump, -10AN feed, -8 AN return, Magnafuel regulator, Aeromotive filter,
Fuel Cell, 95 lb injectors. Works great with no issues....pump is pretty loud.
Old May 1, 2015 | 11:14 PM
Dragframe's Avatar
Those are badass! I want one bad.... Spendy though!
I have the stock tank with home cobbled dual pump setup.. -8 feed.. magnafuel fuel filter, Magnafuel Boost Ref FPR to billet rails... -6 return. Push Lok style fittings. Have some 80# injectors for now. Going to 160s if I can find a good line on ethanol.
I just bought the fuel line kit from Nasty. Nice to know you have everything you need in the kit and Nate's prices are pretty good. He is a lot cheaper than everyone else on the line kits.
Old May 2, 2015 | 05:53 AM
Trayack's Avatar
How are you mounting the 340's and are you running them both all the time or using a Hobbs to trigger one under boost?
- Travis
Old May 2, 2015 | 08:58 AM
luisdm's Avatar
Can you guy also include hp tq numbers you made on your set up.
Old May 2, 2015 | 02:20 PM
turbo6man's Avatar
Just curious how hard you are pushing this? I have same steup except high imp 160's and at 18lbs boost the pump kept up but fuel pressure started to drop level on datalog. Ran 8.8@154. Put boost to 19.5 and pressure dropped more and injector duty cycle went crazy. Tci calculator says 980hp which on e85 I have heard is about right to max out this pump.
Old May 2, 2015 | 05:41 PM
blake b's Avatar
Twin turbo 2010 Camaro 1026whp/962wtq
Stock tank
Squash 400lph (Non E85 pumps) twin set up
Stock feed line converted to 8an then splitting to 6an for each rail.
6an return line
ID1000 injectors
magnafuel FPR
I'm switching to smaller turbos and adding in E85 capability so I'll be changing some things up (pumps and injectors)
