Rx7 TT "Dyno and discussion" thread.
Old Jun 16, 2015 | 11:32 AM
  #101
edwardzracing's Avatar
Originally Posted by coltboostin
There is far too much north of this to bother reading it! But this, I will quote because this is where I am at with life. Lucky, work alots me much free time, about 1/3 of which is parked in front of a computer so I can play patty cake with but-hurt forum warriors. There is a reason I don't work on the car every day, and don't drop what I am doing to go to the track, and its because I enjoy my life too much! Love my kids, work, and what I have done starting from the bottom.
At the end of the day the car is just a toy-something to enjoy when and where I want it. some people will get but hurt over the budget, the performance, and No matter what the opinion is of some lonely, odd guys in the middle of nowhere america, I am still 100% happy with my car, ad its performance thus far. To me, this is all white noise, and will stay that way.
Cheers!
You seriously didn't read his posts? He went to a lot of effort to try and educate you further. My guess is you did read them, but because it was damning to your dyno numbers, you're choosing to ignore them. That or you just don't have the information he inquired about. For someone that is supposedly a world class tuner, your professionalism is shaky at best.
Again, you speak as if we are all just jealous or haters of your build... and again you are incorrect. All we basically wanted to see was some backing up of your numbers with track times and for you to see the light that the printout of your "record breaking" dyno sheet is inaccurate. I think the majority of the "haters" as you call us have all actually paid compliment to your accomplishments and have appreciated what you've done with the build. What is frustrating is that you refuse to believe what countless experts, professionals, published literature, and probably even god if you had a way to speak to him, are telling you about the impossibility of what your dyno has reported. You weren't wrong; the tool was. However, you can't seem to believe that it was wrong for some reason or another. Seemingly because other cars on the same dyno received much more accurate results and then backed them up at the track. Which is still what we're waiting for you to do. Let's not forget that you are the one that brought these dyno sheets to light and immediately threw your name onto the Record List as basically some "new guy from the DSM world that can tune a budget built wooden log to run with nitro boats". You stirred the pot right from the beginning, and if you didn't know what sort of **** storm it would cause, then you're not nearly as smart as you claim to be.
In your other thread you have spoke about being afraid of dying by running the same tune at the track as what was run on the record breaking dyno run (though now I'm not sure if that tune still exists based on these findings of how you don't datalog ****). Regardless, in the same thread you've begun speaking about running more mile per hour and better E.T. Does this mean the fear of dying is no longer there? That you're going to actually run the boost we are wanting to see? Just wondering if that's going to be an excuse again if (when) the car doesn't back up the numbers the next time you run again. I trust that you'll keep us posted.
/end "Hater" response.
Old Jun 16, 2015 | 08:17 PM
  #102
coltboostin's Avatar
Originally Posted by edwardzracing
In your other thread you have spoke about being afraid of dying by running the same tune at the track as what was run on the record breaking dyno run (though now I'm not sure if that tune still exists based on these findings of how you don't datalog ****). Regardless, in the same thread you've begun speaking about running more mile per hour and better E.T. Does this mean the fear of dying is no longer there? .
No, it will go faster if I simply rev it higher with no increase in boost. I had no tach before, so I had no idea when I should have been shifting. It seems like you where not reading....
Torqueshaft brought a lot of new info to the table-which was great! At the end of the day, his math, and ForceFed's math both confirm that the WHP numbers are about right if the CHP at one TRUE bar was int he 370-380chp area. I feel with a free flowing exhaust, no accessories, a great tune, 110+octane fuel and the timing you can add with it, coupled with turbos helping air move through a very restrictive stock intake, this is an achievable number. The only real argument is there.
You either think the car makes the same as a stock motor with stock tune, with full accessories, sucking air through a stock intake-in which case the numbers dont work, or you think the motor is breathing slightly better, in which case the math confirms the whp results.
I appreciate all of the discussion. I don't mind the feed back;positive, negative, or pure hatred, no matter where or why it comes. I know budget build on this scale of all out cheapness rub a lot of people the wrong way. I will still do what I do, and love every minute of it.
Old Jun 16, 2015 | 08:32 PM
  #103
oscs's Avatar
Default Rx7 TT "Dyno and discussion" thread.
Old Jun 17, 2015 | 10:09 AM
  #104
Forcefed86's Avatar
The issue with this thought process, and the issue with your equation, is it does not at all factor in RPM, or the decrease of drivetrain loss percentage as power increases. If your peak HP occurs at a later RPM, you will of course be able to “double” HP vs NA.
My thought process didn’t involve WHP. “The Equation” is just a quick and dirty guess of what could be possible under ideal conditions at the crank. As has been said, you’ll never hit those numbers. You’re original figures weren’t even possible at the crank under these ideal conditions… much less at the wheels.
Since we’ve elevated from 19 to possibly 23-24+ lbs peak and from 870+ to 850whp. 850 crank may have been possible. Since we have no real clue what kind of boost you were making glancing at an inaccurate mechanical boost gauge, we’ll never know I guess. Your 10% drive train loss is pretty optimistic as well. ...but again that argument is opinion and will go nowhere.
With 2 oversized turbos, the curve and peak have all been moved to the right, almost like it would move with the installation of a larger camshaft. Would you agree with this statement? Like you said….the first step is admitting fault.
No. I wouldn’t agree with this. Anytime you add boost the curve and peak will move to the right. They won’t move more than 100% per bar regardless of the turbo size. Changing the cam shaft alters the volume of air the engine can ingest. A turbo cannot do this, so it's a poor comparison.
I will give you that IF the peak RPM was exactly the same and IF the drivetrain loss was the same at all power levels, your rule of thumb should work. I will give you that. But, those 2 ifs are often not reality, and far from it here in my real life example.
Of course not-breathing through a restrictive stock intake, corke’d exhaust, spinning a pile of accessories I don’t have, and without efficient turbos proving a true 1 bar for the cylinders to work with…how could they?! Also if we are talking about what they made at the wheels, my tiny rear gear and paperweight clutch, and light wheels will transmit as much power as possible to the wheels. We all agree that the cool, dry air in the dyno room that day was the perfect storm for making some serious JAM, right?
Humor me. IF the motor at a true 1 bar was moving 380-390chp, that even with your math I’d be at 922-947chp…which at a 10% drivetrain loss equates to 850whp. Is that how your math would work out in that scenario?
I still firmly believe you are WAY overestimating your stock LS1’s crank HP. JY 6.0’s with an aftermarket cam are lucky to be making 25hp per psi. Yet you think your making 27hp per psi with the stock cam at relatively low rpm. IMO, no way in hell 400chp is happening with your motor.
Since that’s an opinion I don’t think we need to argue it any further. Unless you want to put your car back on the dyno without the charge piping and do an NA pull… we’ll never know.
Old Jun 17, 2015 | 01:34 PM
  #105
vettewreck's Avatar
You seriously just did that? He gave you facts, and math that backed it all up, and reasons why your numbers cannot work and your reply is "too much to read"??? You remind me of a x-girlfriend. Just pure insanity and immaturity.
Old Jun 17, 2015 | 01:44 PM
  #106
vettewreck's Avatar
At the end of the day, his math, confirm that the WHP numbers are about right if the CHP at one TRUE bar was int he 370-380chp area.
OMG NO it does not! Thats NOT what he said! Oh yea you didnt read it!!
Again, NO it is not.
And 1 more time, NO it is not. You did not read what he wrote and answered no questions asked. On every number he didnt know (and which you refused to provide) he gave you the great benefit of the doubt. Even giving you ONLY 10% drivetrain loss which he estimates real world numbers of 14-18%.
Simply put, you are a egotistical self centered moron that you believe by avoiding reading a reply means it didnt happen and you can continue on your path of self righteousness.
Old Jun 17, 2015 | 04:32 PM
  #107
Funny, you remind me of my Ex-Girlfriend, that no matter how many times I told her we were done, she kept coming back asking me to ****.
As I said, I appreciate all of the work TorqueShaft and ForceFed have put into this (and give toque major props on raising 6 kids, the real accomplishment here!), and hopefully at the end of the day people have learned the math behind the maddess of forced induction. But, at the end fo the day-the only real disagreement is what my motor would make at a true one bar.
If you think a full exhaust/intake/tune LS1 on 110 octane with added timing at sea level would make less than 350 crank HP, then yes I agree my numbers don't make sense.
If you think exhaust/intake/tune LS1 on 110 octane with added timing at sea level would make 375+Crank HP, then the numbers add up, and the only argument is correction factor.
You my think I am crazy, but I simply think my exhaust/intake/tune LS1 on 110 octane with added timing at sea level would make 375+Crank HP.
Old Jun 17, 2015 | 04:44 PM
  #108
Hank Peabody's Avatar
Here are a whole slew of LS1 dyno’s on a 248 dynojet from a reputable shop.
http://www.speedengineeringanddyno.com/dynotuning.htm
*Healthy* early stock LS1 manual trans stuff dyno’s right around 300whp as I said several times previously.
On that page they list:
100% stock LS1 - Dyno Tuning Tom Pfeifer - Knoxville, TN
and the dyno sheet shows 330whp and 350wtq
330whp * 2.5 bar = 825whp
You kind of proved his point for him with this right?
Old Jun 19, 2015 | 10:07 AM
  #109
SM105K's Avatar
I have a hard believing that bone stock LS1 took over 30 psi of boost.
Old Jun 19, 2015 | 11:19 AM
  #110
1 bar of my calculation is atmosphere.
So its 22psi (1.5 bar) + atmosphere (1 bar). <---PSIA
psig - Measures pressure referenced to local atmospheric pressure and is vented to the atmosphere.
psia - Measures pressure referenced to an absolute vacuum, hermetically sealed at 0 PSIA.
Old Jun 19, 2015 | 01:01 PM
  #111
Forcefed86's Avatar
Not really. Mostly because we don't know the specifics. Also, it's a Dynojet, which isn't an inaccurate representative of real world power to start with.
Couple other points.
Tom P's engine in question was a 2002 SS camaro. Which was rated at a higher 325hp VS the OP's 305hp rating.
Another thing the OP doesn't understand is the turbo itself is more of a restriction exhaust wise than an OEM exhaust system. Of course once boost comes online, it will overcome this restriction easily. That doesn't change the fact that having a turbo at the end of your manifolds affects mass flow/ volume passing through the engine per atmosphere. The diameter at the end of the volute in the exhaust housings is TINY. Also the exhaust wheel itself is a huge restriction.
