procharged, maf question
Old May 5, 2015 | 04:55 PM
sheikss's Avatar
Default procharged, maf question
What maf are you procharged guys running? When the car was na I was using a 85mm gm maf. I have the piece to run a card style maf and will run it if it's better. Which one do you guys recommend?
Old May 6, 2015 | 07:56 AM
ICRAZY6's Avatar
Honestly it depends on how much boost your going to pulley for. Up to 8lbs I've seen people use the stock maf. Over that many choose to tune for Speed density without a maf.
Old May 6, 2015 | 08:49 AM
ramairetransam's Avatar
go with a sd tune . I wasted money on a tune with the maf , i was making 6 lbs and it was fine then i bumped it up to about 8 or 10 dont remember and it wasn't liking it . So had to have it retuned for sd . I wish someone would have told me up front to go speed density .
