T76gts flow rate
Old May 15, 2015 | 09:12 AM
Shownomercy's Avatar
Man-Crush Warning
Default T76gts flow rate
Anyone know the max lb/hr this turbo will do? I can't find a flow chart
Old May 15, 2015 | 09:19 AM
rotary1307cc's Avatar
Nor will u
Old May 15, 2015 | 09:22 AM
Man-Crush Warning
That's what I figured but no chance of finding a cfm?
Old May 15, 2015 | 10:57 AM
ddnspider's Avatar
I spoke with the guys at forcedinductions.com about this years ago and they basically said you could ballpark it if you took a standard 76mm turbo compressor map and shifted the graph 10lb/min to the right since it flowed more.
Old May 15, 2015 | 12:13 PM
Man-Crush Warning
Any rough idea on what it may flow?
Just trying to compare its potential to an F1a
Old May 15, 2015 | 01:51 PM
ddnspider's Avatar
Take the below image from their site and move the island 10 lb/min to the right. Then you'll have an idea based on how much boost you want to run and your NA air consumption.
Old May 15, 2015 | 02:05 PM
Man-Crush Warning
So basically max 103 lbs/min, or about 1400 cfm.
Looks like an f1a will out do me
