Feasibility of stacking MLS gasket layers?
Old May 20, 2015 | 11:34 PM
Forcefed86's Avatar
Default Feasibility of stacking MLS gasket layers?
I don't mean literally laying 2 gaskets on top of each other... But I have tons of used LS9 gaskets in good shape. I'd like to separate the embossed top and bottom layers and stack my own in between? Anyone know what each layer is specifically for and which you would want to stack? Or if this is a bad idea?
Reason I ask is I had to deck my 5.3 block .015. Even with the .051 LS9 gasket I think it may have piston/valve clearance issues. The thicker cometic gaskets may work but they don't seem to seal as well and are very expensive.
Thanks...
Old May 20, 2015 | 11:57 PM
NemeSS's Avatar
Flycut piston?
Old May 21, 2015 | 12:15 AM
Turbo D's Avatar
I am going to do the same thing with the cheap l33 gaskets. I was going to use 1 middle then double up all the other layers.
Old May 21, 2015 | 05:04 AM
etijsma's Avatar
Back in early 2000's vw guys would actually stack head gaskets all the time prior to options being available.
Old May 21, 2015 | 06:56 AM
stevieturbo's Avatar
If you're happy with a higher risk of blowing, work away, but that's purely because of unknowns
But clearly the differing layers do different things. Otherwise all companies would offer the same number or layers, thicknesses etc
The layers are also different types of material.
Old May 21, 2015 | 07:59 AM
Forcefed86's Avatar
Using the OEM pistons, so I’d like to avoid cutting any material off. Thicker head gasket doesn’t bother me, just wondering what the most cost effective route would be.
I have no idea if stacking additional layers is a “good” idea or not. I believe the top 3 and bottom 3 layers of the 7 layer gasket are to assist in sealing while the center layer is just spring steel, mainly for gasket thickness? Can anyone confirm this? I know the top and bottom layers are mainly for water port sealing. The next 4 are raised around the fire ring to assist in sealing and prevent movement.
I was thinking I could drill out the rivet’s that hold the gasket together and add another center layer. I didn’t want to go tearing up gaskets until I knew if this was possible or not. Looking at the Hotrod article they specifically say adding or subtracting layers is an easy way for the manufacturer or a “smart engine builder” to adjust compression ratio. They don’t say which layers are beneficial to “Stack”.
http://www.hotrod.com/how-to/engine/...-head-gaskets/
Old May 21, 2015 | 08:25 AM
LS2 and LS9 are different gaskets, different layers, but same overall thickness.
So the individual layers play more than just filling space, although no doubt some do
I dont see a problem with what you propose, but ultimately there will be risk there. MLS are very forgiving though, and I know people who've even re-used old gaskets with success before.
I dont think I'd put two thick layers right next to each other though unless you can find an OEM gasket that has two like that
Old May 21, 2015 | 08:54 AM
oscs's Avatar
I say you double up the mid section with the thicker spring steel like you propose but throw in a thinner "crush" or seal layer in between them.
 Michael S. Palmer
Old May 21, 2015 | 02:50 PM
ablakez28's Avatar
I basically was going to post this. Now it is common for them to use a shim aka added layer like we are talking about it. A local friend of mine did this and was making around 800-900rwhp in a VW. My mind was blown.
Old May 21, 2015 | 02:51 PM
ablakez28's Avatar
I have reused gaskets in a pinch with copper spray. Held 20+psi so far.
Old May 22, 2015 | 01:14 PM
Tjabo's Avatar
Doesn't Denmah always reuse them?
Old May 22, 2015 | 01:20 PM
Forcefed86's Avatar
Reusing the gasket isn't the issue. It's the stacking of additional layers and which layers I can stack that I'm questioning.
Old May 22, 2015 | 01:23 PM
Tjabo's Avatar
I hear you. I haven't done it, but I was under the impression that it was the center layers that people stacked, possibly with a thin "outer" layer in between them. No idea where I got that impression though. Haha...
Old May 22, 2015 | 03:32 PM
ls1_chevelle's Avatar
honda guys stacked headgaskets all the time hah
Old May 24, 2015 | 12:55 AM
ringgold's Avatar
Don't know any Honda guys that use double stacked hg's, but I do know some VW guys that used to do it back in the day as already posted.
I would think that if you had several OEM gaskets that you could experiment with, you could probably put together a combo that would work well.
Old May 24, 2015 | 10:52 AM
Forcefed86's Avatar
I'm guessing the VW guys were using steel shims that were all the same? It was common practice to add or remove these on SBC stuff as well.
With the LS9 gasket the first 3 layers are different. You have the embossed first layer to help with water sealing. Then the "energizer" which is raised around the cyl bore to help prevent movement. I don't know what the third layer is? (guessing another energizer?). Then the 4th is just flat spring steel. Then it starts over again on the opposite side of the center layer.
I know I could stack the middle layer. But that won't gain me alot of thickness. Wondering if I can stack the 2nd and 3rd layers. And if so, what order would I stack them in?
Old May 24, 2015 | 11:57 AM
etijsma's Avatar
No, we/they actually stacked 2 head gaskets without any modification. Later on companies were making thicker centers attached to the stock outer layers to lower compression.
